[photoshop tut.] a nice glossy effect (like water)
.drago.
I am ALIVE! Profil: Top Penguin
Posted on 01-21-2008 at 12:02:53 AM
water like
exampels:
1st: make a new file 600 x 600 then press Shift+F5 then choose black.
2nd: go Filter>Render>Lens Flare... then make the Brightness: 125px and put the flares like the pic.
it should be like this.
3rd: after finsh from the lens flares go Filter>Sketch>Chrome then put the Detail: 6px and Smoothness: 4px.
4th: then press Ctrl+U to get the Hue/Saturation menu check colorize and make your own color
and the color i used here is
Hue:191
Saturation:100
lightness:0
5th: then after all Duplicate the background.
6th: the layer which had Duplicated make it's Blending mode Lighten then Duplicate it.
7th: the layer which had Duplicated from the lighten layer make it's Blending mode Overlay.
8th: go back to lighten layer and go Filter>Distort>Wave... and click randomize until you get your best shape and then Merge all layers from layer>Merge down
and then Duplicate it.
9th: then make the Blending mode Lighten to the layer which are you Duplicate it then go Edit>Transform>Flip Horizontal then Merge all layers then Duplicate it.
10th:then make the Blending mode Lighten to the layer which are you Duplicate it then go Edit>Transform>Flip Vertical then Merge all layers then Duplicate it.
11th:then make the Blending mode Lighten to the layer which are you Duplicate it then go Edit>Transform>Rotate 90 CW then Merge all layers then we finshed.
itshould be like this
and i know that i say then a lot of times so sry lol
and i hope you like it
Message edited by .drago. on 11-03-2008 at 06:59:38 PM
.drago.
Posted on 01-21-2008 at 12:06:23 AM
ooppss i posted in the wrong place
Damballa
Posted on 01-22-2008 at 04:35:09 PM
nice.. for make some backgrounds
.drago.
Posted on 01-28-2008 at 09:50:16 PM
plz the replays guys
Cerberus1991
Posted on 01-29-2008 at 01:49:38 AM
I got this, it looks nice though Thanks for Tut
.drago.
Posted on 01-29-2008 at 01:59:50 PM
nice result and thx
sFoo
Posted on 01-30-2008 at 12:07:18 AM
very nice, ty
.drago.
Posted on 01-30-2008 at 12:47:56 AM
nice but you forgot most of the steps
Damballa
Posted on 02-06-2008 at 03:40:07 AM
But look more realistic xD
mdyercream8
Posted on 02-16-2008 at 07:28:48 AM
i feel stupid im not getting the lens flare results
darklady
Just remember, art saves lives. Profil: Big Penguin
Posted on 02-16-2008 at 05:26:52 PM
Actually that is pretty right except you need to move the little cross in the center of the "screen". That way it is not all bunched up in one spot.
rolff56
Posted on 03-24-2008 at 08:23:39 AM
Nice tutorial! Thanks a lot! I've learned a lot today
Posted on 03-24-2008 at 09:38:34 AM
Nice result Rolff!
.drago.
Posted on 03-28-2008 at 11:02:51 AM
nice Rolff
Krat0s_
Posted on 03-28-2008 at 06:07:59 PM
Thanks for the tutorial, DeadDragO
.drago.
Posted on 03-29-2008 at 10:27:48 AM
thx Krat0s for the reply and i want to see a result of your work
IronChefofVaaj
Posted on 04-06-2008 at 05:27:49 AM
i know this is off subject but DeadDrAgO what font is that...i think u got it from dafont.com but i cant find it.
thanks
badboioscar
Posted on 06-18-2008 at 03:31:00 PM
im newby thanks for the tut great and simple
heres whatt i got
codenamem2k
Posted on 06-21-2008 at 12:33:19 PM
Here is my result... Hows it??
Posted on 06-21-2008 at 10:11:05 PM
In my opinion a bit too bright, but nice result!
codenamem2k
Posted on 06-22-2008 at 04:03:46 PM
Thanks man... I ll try on changing it
Aelitafan13
Posted on 07-04-2008 at 01:23:46 AM
Here's mine. I call it... Blue Flame:
thetmyster
Life is a maze, Love is a riddle Profil: Penguin Pro
Posted on 10-27-2008 at 05:05:02 PM
Thx nice tutorial
Glomping the internet populace.One forum at a time.
maquire202
I never think of the future. It comes soon enough. Profil: Penguin
Posted on 05-15-2009 at 03:24:46 AM
This is what I got:
thetmyster
Posted on 05-15-2009 at 12:12:43 PM
nice result!
i like rainbows
