25 unknown users
cool lines
n°4317
willem123
Posted on 09-07-2009 at 09:13:03 PM
Hi!! :wink:
This is only my second tutorial so don't expect too much off it :ohwell: , I hope you all understand it! :confused:
In this tutorial I'm going to learn you to make something like this:
http://tutorials.willemweb.nl/krullen/10.jpg
:ar: step 1
Ok, we start we'll start with a new document, use the following settings:
http://tutorials.willemweb.nl/krullen/1.gif
step 2
fill your background with a dark color, I used #65112d (no I'm not gay, I just liked the effect)
:ar: step 3
go to filter>render>Lighting Effects
http://tutorials.willemweb.nl/krullen/2.gif
http://tutorials.willemweb.nl/krullen/3.jpg(sorry for the bad images, it's .gif, so the image doesn't look that good  :oups: )
:ar: step 4
Now, set your foreground color to a lighter variant of your current foreground color. I used #e688a7
:ar: step 5
Choose line tool (http://tutorials.willemweb.nl/krullen/linetool.gif) and draw a random line from the left to the right:
http://tutorials.willemweb.nl/krullen/4.gif
:ar: step 6
Go to edit>transform>warp
play something around like this:
http://tutorials.willemweb.nl/krullen/5.gif
http://tutorials.willemweb.nl/krullen/6.gif
:ar: step 7
make more of those lines (all in different layers)
give all lines APART a nice lighting effect:
http://tutorials.willemweb.nl/krullen/7.gif
:ar: step 8
set the blend mode of the lines to Overlay, Screen or Linear Dodge, so you get a good looking effect:
http://tutorials.willemweb.nl/krullen/8.gif
:ar: final result
You can make as many lines in your piece as you want:
http://tutorials.willemweb.nl/krullen/9.jpg
http://tutorials.willemweb.nl/krullen/11.jpg I gave it a try with blue and purple, that wasn't a success
I hope you all understood it wel! :winktongue:
results are always welcome! :whistle:
Message edited by willem123 on 09-07-2009 at 09:23:41 PM
n°4318
Posted on 09-07-2009 at 09:46:30 PM
Looks pretty cool. :great: I just don't understand how the 'background' layer suddenly got a smooth gradient look? Was that the result of a layer style?
Thanks for the tutorial! :D
n°4319
willem123
Posted on 09-07-2009 at 09:49:11 PM
Thanks Gruzz. It's because all images I submitted are .gif and the one with the smooth gradient look was .jpg so you'd see how it SHOULD look like ;)
I'll see if I can create new images which are clearer
n°4320
Posted on 09-07-2009 at 10:04:28 PM
Ah ok. :yes: Well, about the images is up to you. :) If you think it is important, go for it!
Again, nice and cool result.
n°4321
ghostnatyphon
To die would be a great adventure.
Posted on 09-07-2009 at 10:12:00 PM
Very nice result, and an interesting technique - at first I thought you'd use the pen tool ;) I understood about the image quality, even if Gruzz didn't :p
There is a God :ar: www.ie6nomore.com
Glomping the internet populace http://fc02.deviantart.com/fs48/f/2009/196/0/f/0f93b76ffd0ce94dcd8f1041c69e8b42.gif One forum at a time.
n°4328
willem123
Posted on 09-11-2009 at 08:30:39 PM
Thanks! I'll post some of mine other results later, are there any results yet?
n°4329
thetmyster
Profil: Top Penguin
Posted on 09-11-2009 at 11:54:46 PM
Nice Tutorial :D
May i make a video ??
http://www.crystalxp.net/forum/mesimages/298907/Sig%20No%20bars%20%20%20copy.png
Glomping the internet populace.http://fc02.deviantart.com/fs48/f/2009/196/0/f/0f93b76ffd0ce94dcd8f1041c69e8b42.gifOne forum at a time.
n°4331
Zafar
Genius is nothing but a great aptitude for patianc
Posted on 09-12-2009 at 01:01:28 PM
Thanks willem123for Such a nice tut,Keep it up :great:
http://www.crystalxp.net/forum/mesimages/338927/sign copy.png1..png
n°4332
Posted on 09-12-2009 at 02:51:24 PM
that's a pretty good effort :great:
Igloo <---> DeviantArt
n°4334
willem123
Posted on 09-12-2009 at 03:05:32 PM
thetmyster wrote :
Nice Tutorial :D
Sure :yes: , that would be a honor! :wink:
Are there any results yet??
n°4336
Zafar
Posted on 09-13-2009 at 07:08:53 AM
Here it is :wink:
http://zafarsujal.wordpress.com/files/2008/03/untitled-4-copy.png
http://www.crystalxp.net/forum/mesimages/338927/Untitledfg-4 copy.png
 :mdr:
Message edited by Zafar on 09-13-2009 at 07:12:36 AM
n°4337
thetmyster
Profil: Top Penguin
Posted on 09-13-2009 at 09:47:45 AM
Very nice result on the blue ones :D
n°4338
willem123
Posted on 09-13-2009 at 10:40:48 AM
WOUW :biggrin: ! I really like your result :love: ! :yes:
n°4339
John is best
Posted on 09-13-2009 at 11:01:54 AM
Good Tut willem123 nicely done
and Pretty Work Zafar both are good(specially the blue one)
:sarcastique: John Is Always Best :sarcastique:
 :he: John Means The Best :he:
n°4340
willem123
Posted on 09-13-2009 at 11:41:15 AM
Thanks John is best :great:
n°4341
legace
Posted on 09-13-2009 at 04:05:03 PM
Great tut and even better result! Good work :)
http://uploadpsd.com/file/67463.png
n°4348
willem123
Posted on 09-16-2009 at 07:14:37 PM
Thanks legace :wink:
n°4349
thetmyster
Profil: Top Penguin
Posted on 09-16-2009 at 09:58:58 PM
I cant get it right, do you do lighting effects for every Line?
or just at the begining...
when i get it correct i will make a vid :D
n°4350
willem123
Posted on 09-16-2009 at 10:00:07 PM
You'll have to doe lighting effects for every line appart, that will create a better effect :wink:
n°4351
thetmyster
Profil: Top Penguin
Posted on 09-16-2009 at 10:49:18 PM
thanks :D
i have to sleep now but ill do one tomorrow
n°4353
willem123
Posted on 09-19-2009 at 02:48:48 PM
okay, that's fine! :great:
n°4354
Beerk
Posted on 09-20-2009 at 12:23:17 PM
Nice tuto williem123
n°4361
xciting
Posted on 10-05-2009 at 07:33:57 PM
this is really awesome dude:)
The End iz Beginning Here
n°4362
willem123
Posted on 10-05-2009 at 07:47:40 PM
thanks :great:
n°4380
xciting
Posted on 10-29-2009 at 05:12:27 PM
nice share:)
