18 unknown users
Lightsaber Tutorial
n°3919
maquire202
I never think of the future. It comes soon enough.
Posted on 04-26-2009 at 12:39:33 AM
Photoshop Lightsaber Tutorial.
Let's begin this incredibly simple and fast tutorial.
First find an image you want to add a lightsaber to. I'll use the one below.
http://www.crystalxp.net/forum/mesimages/310958/pic.jpg
Part 1: The Blade
Let's begin.
1. Make a new layer.
2. Use the line tool :psline:  to make a new blade on top of the existing lightsaber on the picture. Rasterize the layer and add little circles at the beginning and the end of the line.
http://www.crystalxp.net/forum/mesimages/310958/pic2.jpg
3. Double click on the layers icon. Enter the following settings.
http://www.crystalxp.net/forum/mesimages/310958/pic3.jpg
You will have to change the glow depending on your picture.
http://www.crystalxp.net/forum/mesimages/310958/pic4.jpg
Part 2: Moving Blade
4. Before giving your blade the glow use the line tool :psline:  to make another line like this:
http://www.crystalxp.net/forum/mesimages/310958/pic5.jpg1..jpg
5. Use the Eliptical Marquee Tool :psellipticalmarquee:  to make a round selection. Adjust it so that the lines touch the border of your selection. Use the lasso tool :pslasso: to get rid of the extra selection. Leave only the round part that touches the lines. This is how it should look.
http://www.crystalxp.net/forum/mesimages/310958/pic6.jpg3..jpg
Select the lines by Ctrl-clicking on their icons and then select the inside using the lasso tool :pslasso: and fill. Press Shift+F5 and fill the selection with any color.
http://www.crystalxp.net/forum/mesimages/310958/pic7.jpg2..jpg
then apply the settings above to this layer.
Part 3: The Light
6. This step is very important to make the saber look realistic. Use a brush tool :psbrush:  with the color of you lightsaber blade and paint over all surfaces that the light from the saber will most likely hit.
http://www.crystalxp.net/forum/mesimages/310958/pic8.jpg
7. In the blending options choose color and change the opacity to your liking.
http://www.crystalxp.net/forum/mesimages/310958/pic9.jpg
And there is your final result:
http://www.crystalxp.net/forum/mesimages/310958/final.jpg1..jpg
"May the Force be with you."
Message edited by maquire202 on 06-29-2009 at 03:25:11 AM
http://www.crystalxp.net/forum/mesimages/310958/signature2.png
n°3920
uttaresh
The Penguin Master
Posted on 04-26-2009 at 01:50:21 AM
LOL, I was just wondering yesterday why there's no lightsaber tutorial on CrystalXP. :he:
One forum at a time.
n°3921
maquire202
Posted on 04-26-2009 at 02:24:02 AM
:lol: i wanna see ur result :yes:
n°3923
uttaresh
The Penguin Master
Posted on 04-26-2009 at 02:42:10 AM
Ummmm ... I already know how to make lightsabers. ;)
n°3924
maquire202
Posted on 04-26-2009 at 03:08:23 AM
oh can u tell me how u do it?  :yes:
n°3925
uttaresh
The Penguin Master
Posted on 04-26-2009 at 03:40:00 AM
Not much to it. Create a new layer over the image. Use the brush tool to make a white, thick line over the lightsaber (make it in some shape like you did if you want it to appear as if in motion). Go to Blending Options>>Outer Glow. Give it the glow of the colour you want, adjust size and spread accordingly. Repeat the same for Inner Glow, if you'd like.
Create another layer under the lightsaber, but over the background. Use the brush tool to colour the areas you want light on. Apply the Gaussian Blur filter for added effect. Adjust Opacity to your liking.
n°3926
maquire202
Posted on 04-26-2009 at 03:45:45 AM
:lol: u just made a tut like 2 sentences long
n°3927
uttaresh
The Penguin Master
Posted on 04-26-2009 at 03:47:43 AM
:p
Well here's what you can do if you do exactly what I just said. ;)
http://uploadpsd.com/file/59966.jpg
n°3928
maquire202
Posted on 04-26-2009 at 03:56:28 AM
Wow nice :great:
n°3929
uttaresh
The Penguin Master
Posted on 04-26-2009 at 04:22:41 AM
Thank'ee. :)
n°3969
thetmyster
Posted on 04-28-2009 at 10:53:31 AM
uttaresh wrote :
:p
Nice Lightsabers Uttaresh and maquire202
Welcome To The Dark Side
 :happy2:
Message edited by thetmyster on 04-28-2009 at 10:56:04 AM
http://www.crystalxp.net/forum/mesimages/298907/Sig%20No%20bars%20%20%20copy.png
Glomping the internet populace.http://fc02.deviantart.com/fs48/f/2009/196/0/f/0f93b76ffd0ce94dcd8f1041c69e8b42.gifOne forum at a time.
n°3976
maquire202
Posted on 04-28-2009 at 10:46:55 PM
Thanks thetmyster
n°4026
Elliott
Yeah, I'm a noob.
Posted on 05-08-2009 at 02:52:14 AM
Dude, thanks. I might try in about an hour or so.
n°4027
thetmyster
Posted on 05-08-2009 at 09:09:27 AM
Hi Elliot I'm looking forward to seeing your results!
I should really do this 2dai but I'm doing my website :p
If I have time I'll try this tut!
n°4175
dienthoaitot
Posted on 07-06-2009 at 04:18:00 AM
thanks you !
n°4176
uttaresh
The Penguin Master
Posted on 07-06-2009 at 04:29:01 AM
Do you have a result? Care to share it with us? ;)
