Genius is nothing but a great aptitude for patianc Profil: Penguin
Posted on 09-08-2010 at 09:48:11 AM
Been a while since I've created a text effect tutorial so I decided I'd do one. In this tutorial I will show you how to create a colourfull text effect using the gradient blend and blur effects.
This is the final result of this tutorial
Step1:
Create a new page, 600x450 is what i used. fill the background layer with solid black.
Step2:
Now we'll add the text. select your preferred font i chose "Brush Script MT" Italic for this.go to blending option>gradient overlay>fill it with spectrum gradient(Compatibale with All Versions of Adobe PS) and set angel at 0 degree.
Step3:
Duplicate The Layer by pressing ctrl+j and this time fill it with solid white color,name the layer Text1.
Now select the text1 layer and press ctrl+j once again to make a copy of Text1 layer.name it as text2
Step4:
Hide Text1 and Text2 layer and Select the Layer Namely "CrystalXP" (the first text layer)
and in the menu go to filters>blur>Gaussian blur and set the blur to 7.
Step5:
Unhide and Select the Layer Namely "Text1"
and in the menu go to filters>blur>Gaussian blur and set the blur to 3 this time.
Step6:
Unhide and Select the Layer Namely "Text2"
and in the menu go to filters>blur>Gaussian blur and set the blur to 1 this time.
you can also change the background to make it more effective
You can also add some Shapes for attraction.
Very Effective For Text Pinching
maquire202
I never think of the future. It comes soon enough. Profil: Penguin
Posted on 09-21-2010 at 02:30:29 PM
hehe I like it! Very nice and simple effect. Nice job! I'll try this when i get back home.
At last some one like it,thanks
bnm123
Posted on 10-26-2011 at 08:42:42 AM
Thi Las Vegas Escort Las Vegas Asian Escorts,Las Vegas Asian Asian Escorhas been backed by surveys by Olivier Luminet and AntLas Vegas Escort Belgium. The pair Las Vegas Escort of the event, US citizens who had rated the attack as Las Vegas Escort more memories, but non-US citizens were were moreemotionally affected by it
