15 unknown users
blending 4 or 5 photos
n°3746
mikame
Posted on 02-02-2009 at 05:29:46 AM
:smile: hello can you please help im new but i have been using adobe photoshop a lot before i just want to know how to make a good blur effect around the edges of each photo...they are all different layers but ive locked them please just give my and tips to make it look nice
thanks :D
n°3747
Posted on 02-02-2009 at 07:32:21 AM
Welcome to CrystalXP mikame. :) You might want to use a white to transparent gradient to achieve what you're after. :yes: Try testing several blurs in the Filters -> Blur menu. Gaussian blur is used pretty often.
n°3748
mikame
Posted on 02-02-2009 at 11:46:23 AM
thanks gruzz...will do :D
im so excited to try out lots of new things :)
n°3760
codenamem2k
Posted on 02-07-2009 at 09:46:35 AM
All the best:)
n°3762
KhainDesign
Posted on 02-11-2009 at 07:27:04 PM
hhmm... i don't have PS on this machine, but as i can remember, you should load the layer as selection (ctrl click on the thumbnail of the layer) and play with the FILTER -> BLUR tools...  but the gaussian blur, is not the best way if you want to blur only the edges... that tool works on the whol selection, or work area... but the easiest solvation is the simple blur tool, with a mid-tone hardness, and a very big diameter... and playing with the mouse... and don't forget to give him some cheese after it :D xD
if you want your 5-4 pictures to be blured into the other, you'd make the upper pic a bit larger, and /w the blur tool blur it's edge. Than use the eraser tool about 150-200px and 0% hardness. this will make an efect of disappearing of the pict over the other.. now blur the lower picture's edge, and you're done ^^,
i hope you see what i mean and it was a good idea for you... :)
n°3840
STIIL
Posted on 03-28-2009 at 12:16:36 AM
ithink the best way is to use masks on the layer
that would make it very easy to correct things
n°3841
uttaresh
The Penguin Master
Posted on 03-28-2009 at 12:34:06 AM
That's what Gruzz meant. ;)
One forum at a time.
