| dazza Profil: Big Penguin | all right all right, listen up! do you want to turn xp into vista??
well its gonna take more than vista inspirat ok... here is what you will need: IMPORTANT set a system restore point before and inbetween installing these programmes i reccomend this for those with abit of spare ram ok. IMPORTANT
vista inspirat 2 TrueTransparency
vistamizer
VTP 9
bootskin
and for those nvidia users at least Geforce MX420(not that important but is still fun)
ok, first get vista inspirat 2, install it, same goes with vistamizer and VTP 9.
then find and install TrueTransparency, then once it is running right mouse click the tray icon and tick run at startup.
ok, now find a programm call ed bootskin, VTP 9 gives a boot skin but it is sh!t so download and install it, then find its folder in your start menue and then click on download bootskins find a vistaish one. download itthen open the bootskin menu and click on file/import. then find its location and select it then make it your boot skin.
ok now it should look pretty good but there is more!!!
ok VTP 9 make xp look like vista buisness but inspirat 2 looks like vista ultimate but VTP 9 over-runs inspirat 2 so dont worry go to google and then images then search vista wallpapers, choose one you like then set it as your wallpaper now you are very close and those without window binds, this is where you get off ok goodbye ...........
pssssssst are they gone??? good ok find an aero flass theme for windowsbindsdownload it and install it to the application... then guess what you do next...USE IT!!!!! ok now you should look pretty happy with ur pc if you didnt like my tutorial or you think it was incomplete please tell me your pc should look something like this: i dont know if the pic will work
by for now not forever  Message edited by dazza on 01-02-2009 at 05:35:06 AM
Neil Chances are not had but gained....... Profil: Penguin Pro | dazza, I don't recommend this so called tutorial of yours because of these First of all We never recommend the installation of a bricopack over any other transformation pack or vise versa since that will permanently replace the XP system files and If a user wanted to reverse back to his previous XP sometimes, He'll never have a chance to revert back Of course VTPs have given errors of unable to revert back even installed stand alone so VTP+Vista Inspirat installation may give a Disaster for someone Secondly about your suggestions, Quote :
vista inspirat 2 TrueTransparency vistamizer VTP 9 bootskin and for those nvidia users at least Geforce MX420(not that important but is still fun)
This will cause your PC to use a large amount of RAM and you'll probably lead in to seizures of the Windows (Unless you're using your PC as a Vista Modeler ) Thirdly The Program Windowblinds that you suggest is a shareware of 30 day Trial period and the users may need to spend 19.95$ to get the fully functioning version And though they get it, It's also uses lots of PC memory so it + the above programs will make an overload on your PC Message edited by Neil on 12-29-2008 at 10:56:01 AM
Gruzz Profil: Moderator | What Neil says is very true. The BricoPack won't put any extra ram on your pc, but the rest of the programs will. | |
dazza Profil: Big Penguin | well it worked fine but then again i do have 2 gig of ram... | |
Neil Chances are not had but gained....... Profil: Penguin Pro | | |
dazza Profil: Big Penguin | ok 2 things i took your advice and tried to uninstall all of themthey all did it fine 2 i use my pc for other things two, i use it for school studies and also my dad uses it cause his pc sh!t itself and he thinks it is still fast, and let me just say im not saying the tutorial is just 4 me i know loads of ppl that have the same, if not more ram than me so i figured that maby it wouldnt p!ss u people off so much ok | |
dazza Profil: Big Penguin | ok thanks im just tryen to help people.
and one more thing VTP is a installer that installa other programs so you can download them seperatley some programs are vistart, viorb, visplore, thoosje sidebar, win flip, rainlendar and and a bootskin(im not shure how they did it).
i recommend to those that are following this tutorial to set a system restore poin before installing each pack ok???
kewl by!!  | |
dazza Profil: Big Penguin | i put a warning at the start ok
Neil Chances are not had but gained....... Profil: Penguin Pro | Good
But no need of a double post for that  | |
KhainDesign Profil: New Penguin | hmm... not bad but as i think of the whole result, i'll think i chose the Leopard skin.... but anyways a good idea....  | |
