25 unknown users
[Photoshop tutorial] How to use the Quick Mask Mode
n°3050
k-net
Posted on 06-24-2006 at 11:42:46 PM
original tuto (in french)
This tuto is going to teach you how to extract sub parts of a picture without using the magic wand (which is not precise) and faster than using the pen tool. An example where using the Quick Mask Mode would have been useful : this topic...
The Quick Mask Mode is unfortunately no very used, but after you read this tuto I'm sure you'll use it more often.
Let's take an example : I want to extract the girl in the foreground.
http://k-net.crystalxp.net/2006/05/08/tuto_quick_mask/01.jpg
Try with the Magic Wand tool : impossible ! it doesn't work correctly because the caracters around have the same skin and chothes colors...
http://k-net.crystalxp.net/2006/05/08/tuto_quick_mask/02.gif
So what are we going to do ? Here's the solution : use the Quick Mask Mode.
It's very easy to use it, first of all we delete any already present selection by doing Ctrl+D. Then we set the Quick Mask Mode by clicking on the right button in the Toolbar :
http://k-net.crystalxp.net/2006/05/08/tuto_quick_mask/03.gif
We can also press Q.
Now let's select the Brush tool (Diameter depends of the precision you want and Hardness must be at 100%)
http://k-net.crystalxp.net/2006/05/08/tuto_quick_mask/04.gif
Set black in foreground color :
http://k-net.crystalxp.net/2006/05/08/tuto_quick_mask/05.gif
Then the selection starts : we're going to "paint" the zone we want to select (if needed, zoom on the picture to be more precise).
And now, miracle, the brush paints in red :oh:
This red trace is actually the zone wich will not be in our future selection.
http://k-net.crystalxp.net/2006/05/08/tuto_quick_mask/06.gif
If needed, we can correct little details with a smaller brush :
http://k-net.crystalxp.net/2006/05/08/tuto_quick_mask/07.gif
Once the trace is done, we reput the Standard mode to use our new selection by pressing Q :
http://k-net.crystalxp.net/2006/05/08/tuto_quick_mask/08.gif
The non-red zone becomes selected :
http://k-net.crystalxp.net/2006/05/08/tuto_quick_mask/09.gif
Well, it's done, we can now extract the part from the picture, change background, etc...
Examples :
http://k-net.crystalxp.net/2006/05/08/tuto_quick_mask/10.gif
http://k-net.crystalxp.net/2006/05/08/tuto_quick_mask/11.jpg
http://k-net.crystalxp.net/2006/05/08/tuto_quick_mask/12.jpg
Additional remarks :
You can also use this mode in the way normal selection/mask selection (quite useful when you've already started to select in the picture)
http://k-net.crystalxp.net/2006/05/08/tuto_quick_mask/13.gif
You can adjust Brush opacity to change selection opacity :
http://k-net.crystalxp.net/2006/05/08/tuto_quick_mask/14.gif
We can use other tools than the Brush mais this one is the easiest the make standard selections...
PS: I translated the tuto by myself (I'm french), so there can be mistakes (I think there are :mdr: ) : just tell me :wink:
n°3051
Neil
Posted on 06-25-2006 at 12:04:29 AM
Nice Translation K-net :great: and thank you very much This is what I've been looking for a long period :smile:
Voila,
Well / Wow / Now
This tuto is going to learn
teach is better
but after you've read this tuto
The non-red zone becomes selectionned :
Selected
Util remarqs :
Additional Remarks :wink:
n°3052
k-net
Posted on 06-25-2006 at 12:18:40 AM
Edited !
Once more, thank you, Neil :jap: :cool:
n°3053
Neil
Posted on 06-25-2006 at 12:37:02 AM
Edited !
You're welcome K-net :loveit:
Additional remarqs :
it should be remarks :mdr:
n°3054
k-net
Posted on 06-25-2006 at 12:38:48 AM
:lol:
Thanks again, edited :wink:
n°3055
rk2
Posted on 06-25-2006 at 10:48:48 AM
nice tuto ! thank's you :wink:
and one more to k-net   :penguin:  :penguin:  :penguin: :penguin:  :penguin:  :penguin:
n°3056
Skynix
Profil: Top Penguin
Posted on 06-25-2006 at 10:53:49 AM
So nice translation ! Good Work K-Net !  :great:
n°3057
k-net
Posted on 06-26-2006 at 01:10:11 PM
Thanks :jap:
n°3058
Pyro
Posted on 06-26-2006 at 01:20:41 PM
Good translation k-net ! And nice tutorial too !  :jap:
n°3073
chikitito
Posted on 07-22-2006 at 03:03:30 PM
nice tutorial!  :jap:  nice choice of which part to extract too!! :lol: :wink: :lol:
