27 unknown users
How to create Animated PNG
n°2996
ghaniz786
Posted on 03-26-2006 at 11:41:10 AM
HI
Dear Guys
I want to know that how can i create animated png for simple animated dolet. I don't how to explain that but when we open it, it shows all frame one by one in one file i mean one frame.....I hope you understand i can't explain  :ouch: :frown:
n°2997
Skunkie
Posted on 03-26-2006 at 12:37:50 PM
the PNG format does not support animations.
n°2998
batux
Posted on 03-26-2006 at 12:38:45 PM
Hi, welcome :jap:
If you want animated picture with transparency, you must use GIF format :great:
n°2999
Buck
Lécher les papillons, c'est mal.
Posted on 03-26-2006 at 03:02:01 PM
Hum... I think that you can ue the MNG format (MovingNG), but how ? I really don't know... It's a special PNG format...
n°3000
Profil: Admin
Posted on 03-26-2006 at 03:05:15 PM
Animation Shop Pro use MNG  :cool:
n°3002
ghaniz786
Posted on 03-26-2006 at 11:31:21 PM
OH yeah it is called mng thanks for help  :loveit:
n°3003
InteRNaZional
Posted on 03-26-2006 at 11:33:18 PM
Welcome to CrystalXP ghaniz786 :cool:
n°3004
ghaniz786
Posted on 03-27-2006 at 12:24:59 AM
isn't there any other soft ware ? animation shop pro is combined with PSP and too heavy software. 324MB  :xeyes:
n°3005
Skunkie
Posted on 03-27-2006 at 01:16:08 AM
not sure how much this will help, but here is a page about applciations with MNG support:
http://www.libpng.org/pub/mng/mngapps.html
n°3006
vaksa
Profil: Top Penguin
Posted on 03-27-2006 at 02:46:27 AM
Also exists APNG format. You can read here about it.
And welcome to CrystalXP :smile:
n°3008
ghaniz786
Posted on 03-28-2006 at 02:53:56 AM
Thanks All of you it is really helpfull  :cool:
n°3521
einsiol
Posted on 11-11-2008 at 01:42:36 PM
I want to make a note for anybody how is getting this in there google result.
Animated PNG is now call APNG, to make a APNG one of the best tools is the APNG editor plug-in for Firefox, it makes use of the APNG engien in the firefox to edit and great a APNG.
APNG edit
One thing I don't know, is how to extract frames from videos (more then 1 frame a sec) and swf files. :P
Message edited by einsiol on 11-11-2008 at 01:44:46 PM
n°3522
Neil
Everyday is a Countdown
Posted on 11-11-2008 at 01:51:57 PM
Hi einsiol and Welcome to Crystal XP :loveit:
Thanks for sharing what you have figured with us ;)
An Animation/Video is a simultaneously running frames ;) (39fps 25fps) GiF or APNG is of the same type but has lower frames per second rate So for a proper editing application, Extracting the actual running frames is not that difficult :yes:
http://i404.photobucket.com/albums/pp122/iSe7en/Uber.png
I'm not an agent but a fan of Crystal XP
n°3528
thetmyster
Profil: Top Penguin
Posted on 11-11-2008 at 10:29:12 PM
Flash cs3 could do it if you converted to flv then opened in flash and found the right frame but it would take a lifetime! :ouch:
http://www.crystalxp.net/forum/mesimages/298907/Sig%20No%20bars%20%20%20copy.png
Glomping the internet populace.http://fc02.deviantart.com/fs48/f/2009/196/0/f/0f93b76ffd0ce94dcd8f1041c69e8b42.gifOne forum at a time.
n°3530
Neil
Posted on 11-12-2008 at 07:29:11 AM
I think it's easier in Image Ready CS3  :jap:
n°3533
thetmyster
Profil: Top Penguin
Posted on 11-12-2008 at 09:52:55 AM
... i thought they got rir of image ready and embedded it in PS CS3...
:confused:
