34 unknown users
 Page :  1  2  3  4
Next
Creat Vista wallpapers by Dohoavn.net
n°3414
Frozzn
Posted on 09-11-2008 at 08:22:49 PM
http://farm4.static.flickr.com/3051/2848241927_01acaa2bbe_o.jpg
These try doesn't look very good. I go to make a second...  :xeyes:
(The lines aren't ok)
n°3415
Posted on 09-12-2008 at 02:27:07 AM
Well try Frozzn but why are the lines not curved as they should be?I think perfection of those curvy lines will bring much improvement in your result :oui:
n°3416
Frozzn
Posted on 09-12-2008 at 04:54:04 PM
SO, here's my final version:
http://farm4.static.flickr.com/3162/2851109672_3253d57807_o.jpg
8The old image is deleted ^^)
n°3417
ghostnatyphon
To die would be a great adventure.
Posted on 09-12-2008 at 09:11:30 PM
Looks pretty good :great: Maybe it could be improved by adding some thinner curvy lines with the fairly thick ones you currently have :oui:
n°3436
thetmyster
Profil: Top Penguin
Posted on 10-21-2008 at 07:35:26 PM
ARE THERE ANY NOOB PROOF TUTORIALS ???
(IVE TRYED NOVICE CORNER!;)
n°3437
ghostnatyphon
Posted on 10-21-2008 at 08:27:42 PM
Please don't use caps lock all the time :angel:
If you are wanting "noob-proof" I strongly suggest you find some very simple tutorials to teach you about the tools of the graphics editor you're using, that way the slightly more "advanced" tutorials will become easier to understand :wink:
n°3490
dura007k
Posted on 11-01-2008 at 12:40:35 PM
Can anybody tell me how to create this wallpaper with Photoshop CS3 Extended
Look your results:
http://i77.servimg.com/u/f77/12/07/81/43/410.jpg
Look my result:
http://i77.servimg.com/u/f77/12/07/81/43/untitl10.jpg
It isn't same, they are different
Please look and compare and tell me how can I create these lines PLZZ
Creating these lines with Photoshop CS2 is different with creating these lines with Photoshop CS3
I'm waiting for your answers ;)
Message quoted 1 times
Message edited by dura007k on 11-01-2008 at 12:42:18 PM
n°3491
Posted on 11-01-2008 at 04:34:17 PM
No it is done in the same way. :yes: You just haven't read careful enough. You have to set your brush to a hard brush of 3 pixels. Then choose the stroke option again. :) Now your lines will look the same.  :wink:
n°3492
dura007k
Posted on 11-02-2008 at 09:51:02 AM
Thnx man, You know where was the mistake :ohwell:  Stroke Path>Simulate Pressure It was OFF :oups:
Soon I show my result;)
n°3494
Tanshin
Posted on 11-03-2008 at 10:35:22 PM
Okay, here are my results, I can't decide where I want the logo to go...
http://i15.photobucket.com/albums/a398/saladbar1/orbdesk.png (see later post)
http://i15.photobucket.com/albums/ [...] bdesk2.png
Message edited by Tanshin on 11-04-2008 at 04:43:24 PM
http://i15.photobucket.com/albums/a398/saladbar1/snowleopardbar.png
Glomping the internet populace. http://fc02.deviantart.com/fs48/f/2009/196/0/f/0f93b76ffd0ce94dcd8f1041c69e8b42.gif One forum at a time.
n°3495
Posted on 11-04-2008 at 08:17:10 AM
I like it Tanshin! :D The purple color works really well. ;)
n°3496
Tanshin
Posted on 11-04-2008 at 04:26:46 PM
I don't know why that first one is so small... I'll have to re-upload it.
Okay, I fixed the shrinking problem:
http://img240.imageshack.us/img240/3876/orbdeskco1.png
Message edited by Tanshin on 11-04-2008 at 04:45:53 PM
 Page :  1  2  3  4
Next
Top
