10 unknown users
 Page :  1  2  3  4
Creat Vista wallpapers by Dohoavn.net
n°3387
Posted on 07-06-2008 at 10:44:34 PM
Looking pretty sweet and fresh! :oui: There's also a tutorial specifically on the Pen Tool on here, written by me. :smile: Check it out if you want to learn more about the Pen Tool. It's something you're probably going to use very often if you progress in Photoshop.
n°3388
IronChefofVaaj
Posted on 07-07-2008 at 12:56:30 AM
-edited-
jk guess i have to go read your tut... :frown:
n°3389
Posted on 07-07-2008 at 10:22:11 AM
Keep your language appropriate if you post here. :oui: Else you will be warned and your posting rights may be taken.  :mad:
n°3390
ghostnatyphon
Who Dares Wins
Posted on 07-07-2008 at 05:57:48 PM
Thanks for the link to the tut Gruzz, I've read it before though, first place I went  :tongue:
One thing I didn't think of was the darned little bar at the top that Asher posted, I'm not so used to photoshop and I keep forgetting about the little bars and menus  :oups:
I added some wavy lines with the pen tool now, but didn't think to use a gradient instead of a solid fill  :redface:
Is there a tut somewhere that shows how to make the wavy lines by the way? I can't quite get them right  :arf:
n°3391
Damballa
Posted on 07-07-2008 at 06:48:18 PM
Im not patient to do nices line or brushes.. i do it random and they are ugly :tongue:
n°3392
Posted on 07-07-2008 at 11:48:13 PM
Ghost :ar: After creating a curve (the path should not be closed) , right click on the curve with the Pen-Tool selected and select 'Stroke Path' from the menu
http://img187.imageshack.us/img187/1558/strokeup9.jpg
then select 'Brush' from the "Tools" menu in the next option , you should select appropriate settings for Brush-Tool before using it for path :wink:
n°3393
Posted on 07-08-2008 at 11:43:49 AM
Asher wrote :
Ghost
Usually a 2px brush (hard or soft, try what works best for you) with a light colour works well for these kind of lines. :wink:
n°3394
ghostnatyphon
Who Dares Wins
Posted on 07-08-2008 at 12:55:55 PM
Sorry didn't explain what I meant by wavy lines; I meant the lines like on the crystalxp banner, where they have a gradient on them.. hard to explain. Like the ones in Gruzz and Asher's sig, where the lines have a gradient kind of background and are transparent...
Is that just using the pen tool so it fills the path and then connecting the lines up outside of the canvas area? And then with a gradient fill and 20-40% opacity kind of thing?
n°3395
Posted on 07-08-2008 at 05:03:03 PM
You got it correct :oui: except that I've used Pen-Tool curves on my signature :he:
n°3396
yakashi
Posted on 07-08-2008 at 09:59:38 PM
Hi im new in crytalsxp but here this is my result after hardworking: thanks for the useful and helpful tut ^^
http://img293.imageshack.us/img293/3082/tommyv2mx9.jpg
:neutral:
n°3397
Aelitafan13
Posted on 07-08-2008 at 10:10:58 PM
Great Job. :great:. Though I don't understand why its that big, but great job. ^^
n°3398
yakashi
Posted on 07-08-2008 at 10:14:02 PM
yay idk it too^^ um i have fixed it so it smaller now  :tongue:
n°3399
ghostnatyphon
Who Dares Wins
Posted on 07-09-2008 at 02:28:15 PM
Made another one with this, using the pen tool and gradients to make some waves ^^ (oh sorry for the out-of-date theme, just seemed to fit the colours :tongue:)
http://i184.photobucket.com/albums/x1/darthsmall9/SpringWallpaperGhostPNG-1.png
How's it look? (It's actually 1024x800 but photobucket won't let me upload that high >:/)
n°3400
dura007k
Posted on 07-17-2008 at 08:24:31 PM
I tried but I don't know how to do that lines :frown:
http://i215.photobucket.com/albums/cc10/Sweet_boy1030/4.jpg
Please anybody tell me
n°3401
Posted on 07-18-2008 at 12:01:08 PM
dura007k, could you be a bit more specific? :angel: Do you not know how to make this shape with the Pen Tool, or how to go from there? :smile:
n°3402
headbuster
Posted on 07-21-2008 at 08:49:22 PM
I don't know ho to make the lines too :ouch:
n°3403
Posted on 07-21-2008 at 09:53:02 PM
Have a look in this tutorial. :oui: It'll describe a lot of information regarding the Pen Tool. This will help you make the wavy lines. :oui:
n°3404
headbuster
Posted on 07-22-2008 at 09:11:16 AM
Thanks a lot!
Nice tut!
n°3406
dura007k
Posted on 08-09-2008 at 03:22:39 PM
Yes, I don't know how to make this shape with the Pen Tool :neutral:  :neutral:
n°3407
ghostnatyphon
Who Dares Wins
Posted on 08-09-2008 at 04:19:16 PM
Using the pen tool, click on a point outside of the canvas (The grey area) and then click again on a point on the canvas (a point on your background).
Now you should have a straight line, with a dot at either end.
Then click and hold at a point somehwere at the middle of the line (You can do this at any point tough) and then drag the mouse (Still holding down the mouse button) away from the line and you should see the line you made start to curve the more you drag away from the line.
The drag the mouse around until you get a shape you like, and let go.
Hope that helps you :smile:
n°3408
iraqia
Posted on 08-20-2008 at 04:18:10 PM
woww :eek:
so nice  tutorial    :cool:
thank u :oups:
n°3410
Frozzn
Posted on 09-08-2008 at 12:44:16 PM
WOW, very nice  :oui: . But how did you make step 2? I can't draw this round lines  :neutral: .
n°3411
Posted on 09-08-2008 at 03:25:41 PM
When you put down a point, make sure to drag a bit. Now you will get two controllers which you can use to drag. This way you're able to get a curved path. :oui: If you still don't understand, have a look at my Pen Tool tutorial.  :happy2:
n°3412
Frozzn
Posted on 09-08-2008 at 05:08:25 PM
Thanks  :smile: . I try it ^^.
n°3413
dura007k
Posted on 09-11-2008 at 07:08:36 PM
Hey bro fix images because these doesn't look :frown:
Sorry for my bad English :frown:
n°3414
Frozzn
Posted on 09-11-2008 at 08:22:49 PM
http://farm4.static.flickr.com/3051/2848241927_01acaa2bbe_o.jpg
These try doesn't look very good. I go to make a second...  :xeyes:
(The lines aren't ok)
 Page :  1  2  3  4
Top
