| Sweet_boy1030 Profil: New Penguin | | |
valoesdte Profil: New Penguin | Wow this is helpful. Thank you I am going to try this right now! | |
baldr Profil: New Penguin | Real nice tutorial  | |
Krat0s_ Profil: Big Penguin | Very good and useful tutorial !  | |
costin Profil: New Penguin | thank you  | |
darklady Just remember, art saves lives. Profil: Big Penguin | | |
Dark_RAIDEN_ Profil: Big Penguin | cool! it looks really good but i don't have PS though so i can't do it. | |
Martian89 Profil: New Penguin | With wich tool exactly do you draw the lines? I tried it just with the brush at 100% hardness but I can't make my line like the way you did it. (making it go smooth over de points you set.) | |
Gruzz Profil: Moderator | I just used the Soft Mechanical 1 pixel brush and it looked pretty alright. The smoothness of the line mostly depends on how well you set your points with the Pen Tool.  | |
poiru Profil: Moderator | Good tuto! I love the style and I am going to test this right away  | |
design maker don''t waste time, be active! Profil: Penguin | thanks, Really it's a Great... tutorial  | |
Sweet_boy1030 Profil: New Penguin | OH!! Your wallpapers is very good!! ^_^!!
darklady Just remember, art saves lives. Profil: Big Penguin | Thanks  | |
Krat0s_ Profil: Big Penguin | Yes, very good wallpaper DarkLady!  | |
mdyercream8 Profil: New Penguin | how do you choose stroke path? i ish stupid....still | |
Gruzz Profil: Moderator | You've to go to the paths tab for that. Then right click on the path that you want to see stroked and select 'Stroke Path'.  | |
mdyercream8 Profil: New Penguin | ohhh i get it i give you all mah results later  | |
Gruzz Profil: Moderator | No problem! You are able to get fantastic results with this stroke thing by the way.  | |
codenamem2k Profil: Big Penguin | Good tuto man... I am working on my wallpaper... Will show the result when its done Once more... great work!! | |
codenamem2k Profil: Big Penguin | Iam done!! Here is my result: | |
Asher Genius is not born , it is made.... Profil: Moderator | Very nice but don't you think that there's too much density of white dots? | |
codenamem2k Profil: Big Penguin | Yeah.. I did a bit of modification... and here is the results: | |
darklady Just remember, art saves lives. Profil: Big Penguin | Very cute! Though I think the shadow on the tux could have been done just a little better. Nonetheless a very nice piece! | |
codenamem2k Profil: Big Penguin | Thanks DarkLady!!  | |
mdyercream8 Profil: New Penguin | well heres mine i combined a few other tuts i scavenged up
