~Styler Tutorial~
OK here's the deal, I teach you to install skins to your styler, you download my creation at
http://igloo.crystalxp.net/yifan! Deal??? OK, let's begin.
1) First, find a skin of your choice (like duh!!?) and open it, don't save it.
2) For me I use WinZip, or you might also use other softwares you like too, but I recommend WinZip! Secondly, you would see a list of shells, folder, skin etc. in your compression utility (WinZip) window. Select all the items and extract them to the folder, C:\Program Files\Styler\msstyles .
3) Third, go back to Styler's folder C:\Program Files\Styler. Run Styler and you will see a list of thumbnail of the various default skins. Drag the folder C:\Program Files\Styler\msstyles to where the thumbnails are, your chosen skin would be on that list and EUREKA!!! the skin can be applied!!!
Isn't that easy??? Installing skins into Styler in 3 simple steps!!!
Thanks very much for looking at my tutorial!!!
