wlasta General & Off Topic Discussion : Neil and 34 unknown users
Alian Text Effect
n°3284
.drago.
Leaved this forum for a bit!!
Profil: Top Penguin
Posted on 11-18-2007 at 01:10:43 PM
Alian Text Effect
it's an effect for text
here look at this
http://img207.imageshack.us/img207/9495/alianep7.png
the Tutorial:
1st: go File>New (Ctrl+n) put the resize you want.
2nd: press Shift+F5 and choose the color you want.
3rd: use the Text tool (or press T) write any thing you want and choose the color of it.
4th: press Ctrl+left click on the Text layer then go Select>Inverse (or press Shift+Ctrl+I).
5th: go Filter>Blur>Radial Blur
http://img204.imageshack.us/img204/2088/radialblurdj4.jpg
6th: then press Ctrl+f (x2)
it should be like that
http://img122.imageshack.us/img122/1131/prvxu9.png
you just have 1 Error
7th: look at the letter how have holes the holes will not seen
you must use the lasso tool (press L)
then select the holes
http://img67.imageshack.us/img67/2285/lassotooljo7.jpg
8th: then select Eraser tool (press E) and make its Opacity=24%
http://img122.imageshack.us/img122/2268/optionsvo8.png
then run on it 1 time
the final image
http://img122.imageshack.us/img122/2668/finalsj0.png
we finshed now and i hope you like it
and plz the reply
n°3286
Yozgat_BOY
Posted on 11-18-2007 at 02:40:51 PM
veryy goodd thanks :smile:)
n°3289
sasori sama
Posted on 11-18-2007 at 06:38:09 PM
thats nice and thanks
n°3292
.drago.
Profil: Top Penguin
Posted on 11-19-2007 at 06:59:02 AM
thx all
n°3300
.drago.
Profil: Top Penguin
Posted on 11-22-2007 at 02:29:49 PM
the replays plz guys plz don't see it only you must reply
tell if it bad , good any thing put your comment
n°3502
codenamem2k
Posted on 11-08-2008 at 11:38:47 AM
Well, here is my result:http://img393.imageshack.us/img393/680/3ddesignva2.png
Hows it???
n°3503
uttaresh
The Penguin Master
Posted on 11-08-2008 at 12:27:28 PM
Here's my go:
http://img291.imageshack.us/img291/4402/notfatqq3.png
One forum at a time.
n°3507
ghostnatyphon
To die would be a great adventure.
Posted on 11-08-2008 at 09:56:02 PM
Doesn't look like you followed this tutorial :p
There is a God :ar: www.ie6nomore.com
Glomping the internet populace http://fc02.deviantart.com/fs48/f/2009/196/0/f/0f93b76ffd0ce94dcd8f1041c69e8b42.gif One forum at a time.
n°3538
codenamem2k
Posted on 11-12-2008 at 05:41:57 PM
Sorry... wrong placement ;)
Message edited by codenamem2k on 11-12-2008 at 05:52:31 PM
