13 unknown users
[Paint.NET Tutorial] Create 3D "Gelatin" Text
n°3258
aguba
Posted on 09-10-2007 at 03:20:24 AM
This will show you how to create the 3D "Jello Text". The plugins needed to do this are the Feather Plugin and the Transparency Plugin, which can be found in the Paint.NET Official Forum. The end result will look like this:
http://i56.photobucket.com/albums/g192/aguba12/aguba3D.png
To start off, start with a new image, any size.
Create a new layer. Turn off anti-aliasing and write in your text  in a color of your choice. Name this layer "Text".
http://i56.photobucket.com/albums/g192/aguba12/JelloTut1.png
Using the magic wand  , select all of the transparent areas around the text and invert the selection(Ctrl+I). Create a new layer and choose a lighter version of the color you used for your text as your primary color and a completely transparant color for your secondary color. Using the gradient tool, create a radial gradient starting from under your selection to above it.
http://i56.photobucket.com/albums/g192/aguba12/JelloTut2.png
Merge this layer into the text layer. Duplicate the text layer and name the lower one 3D. Do a motion blur  on the 3D layer at a -90 degree angle, and make sure that "Centered" is off. The distance of the motion blur depends on how thick you want the letters to be. Using the Transparency plugin, adjust the transparency to be 100% opaque.
http://i56.photobucket.com/albums/g192/aguba12/JelloTut3.png
On the text layer, select all the transparant area around the text. Create a new layer, name it "White", and fill the selection with white. Feather the White layer by 10.
http://i56.photobucket.com/albums/g192/aguba12/JelloTut4.png
Once again, on the text layer, select the transparant areas. Switch to the White layer and delete the selection. Merge the White and Text layers.
Switch to the Text layer and select all the transparent areas. Invert the selection (Ctrl+I) and create a new layer. Name this new layer "Gloss". Using the Rectangle  tool set at Draw Filled Shape  , create a white rectangle in the selection. Make it semi-transparent using the Transparency plugin. Merge the Gloss and Text layers together.
Merge the Text and 3D layers together and apply a Glow  to finish.
n°3259
Posted on 09-10-2007 at 12:07:09 PM
Thank you for the tutorial, we didn't had much Paint.NET tutorials before. :wink: I think your end result looks very cool too! Please read the rules, your signature is (much) too big! :oui:
n°3260
krystof..,-
Posted on 09-10-2007 at 01:20:54 PM
Hey thanks for this nice tut, should work with Gimp or Photoshop, too  :great:
n°3261
Posted on 09-10-2007 at 05:56:40 PM
Simple and nice :happy2: good job aguba and welcome to Crystal XP :yipi:
n°3276
fixiale
Posted on 10-22-2007 at 01:58:04 PM
http://img86.imageshack.us/img86/2613/quakewallpaperbriterv8.jpg
Got this when I failed. I quite like it though. I then redid it with a dark background and light text.
n°3277
Posted on 10-22-2007 at 08:29:51 PM
Pretty nice Fixiale! :smile: Why don't you use a transparent background next time? :wink:
n°3278
fixiale
Posted on 10-27-2007 at 05:26:09 PM
That's a good idea! I'll keep it in mind, thanks for the idea.
:biggrin:
n°3405
firebird75
Posted on 08-05-2008 at 10:02:49 PM
Nice one, great job! Looks so easy like this :wink:
n°3670
v0dSkaa
Posted on 01-07-2009 at 11:36:22 AM
i want a tuto to do the same as fixiale xD
n°3678
codenamem2k
Posted on 01-10-2009 at 06:50:53 AM
Well, could someone give a PS Tutorial to do the same thing please..
n°4278
elloguvna1
Posted on 08-12-2009 at 06:21:32 PM
http://i56.photobucket.com/albums/ [...] guba3D.png
 http://i56.photobucket.com/albums/ [...] loTut1.png
 http://i56.photobucket.com/albums/ [...] loTut2.png
http://i56.photobucket.com/albums/ [...] loTut3.png
http://i56.photobucket.com/albums/ [...] loTut4.png
I followed everything you said to do but it doesn't turn out right. I don't know what I am doing wrong :(. Mine just turns out flat with a glow to it. It doesn't turn out the way yours did (with it being 3D and stuff). Could you or someone help me out. I did download the transparency plugin and the feather plugin.
n°4279
Posted on 08-12-2009 at 08:47:59 PM
Perhaps you can show us your image elloguvna1. :yes:
n°4281
elloguvna1
Posted on 08-13-2009 at 12:38:42 AM
I am sorry I tried to but my internet is annoying and it keeps disconnecting on me everytime I try to upload it  :grrrrrr: . But I will keep trying to upload the image and post it whenever I can.
