Graphic Mutual-Aid : mypeobjeree and 30 unknown users
[Paint.NET] Electeric Tut.
n°3247
Bigj130
Posted on 07-30-2007 at 10:18:07 PM
This is my first tutorial..
If you think i left out any information, tell me!
Thanks! :mdr:
1. First you start as your name (or what ever you like) and have the back ground black.
http://i55.photobucket.com/albums/g129/jared311/1-1.jpg
2. After that, you Hold Ctrl+A (That will selected the hole image) And copy it into another layer...
http://i55.photobucket.com/albums/g129/jared311/2-1.jpg
3. After you have done that you Go to the layers Properties and select Negation...
http://i55.photobucket.com/albums/g129/jared311/3-1.jpg
4. Next, add the Cloud effect on the First Layer...
http://i55.photobucket.com/albums/g129/jared311/4-1.jpg
5. On the second layer you should put Gaussian Blur...
http://i55.photobucket.com/albums/g129/jared311/5-1.jpg
6. And after all of that it should look like this...
http://i55.photobucket.com/albums/g129/jared311/6.jpg
7. To add color to your Art* Go to Adjustments > Curves!
http://i55.photobucket.com/albums/g129/jared311/7-1.jpg
It should look like this!
http://i55.photobucket.com/albums/g129/jared311/8Finished.jpg
Thanks for looking at my tut!
I would like to see what yours looks like, so post them!
THANKS! :mdr:
n°3248
Bigj130
Posted on 07-31-2007 at 01:37:13 AM
*This is how to make it look a little better.....
First Make a new Layer...
1. Go to the color window and Click the second color (Default: White) and make it Gone?
http://i55.photobucket.com/albums/g129/jared311/1-2.jpg
2. Put the Tolerance to 100% and changed the Solid color to Vertical Lines....
http://i55.photobucket.com/albums/g129/jared311/2-2.jpg
3. Go to Layer Properties and change the Opacity...
http://i55.photobucket.com/albums/g129/jared311/3-2.jpg
And this is what it looks like after its done!
http://i55.photobucket.com/albums/g129/jared311/Done.jpg
n°3249
Posted on 07-31-2007 at 08:33:23 AM
Thank you for the tutorial. :loveit: Getting tutorials for other programs then Photoshop is great. I don't understand this step though, maybe you can explain.
n°3262
aguba
Posted on 09-11-2007 at 02:17:40 AM
I believe he means to make the second color fully transparent.
