29 unknown users
Program for mirror
n°3814
Callum76
Posted on 03-12-2009 at 07:35:06 PM
Hi, I write because i am looking for a program that imports in mass simple images (jpeg, bmp etc) and creates for each of them an image 4 times bigger, composed by the original image copied and mirrored.
Let me explain: in the final image, in the top left there is the original image, in the top right the original image mirrored by the vertical axis and in the bottom these 2 images mirrored by the horizontal axis.
Do you know a program that do this, apart from photoshop?
I don't want to install photoshop because I already use fireworks for all the common graphical operations.
Thank you
__________________
You have never see gift like these? (geschenkideen on german cultura generale)
n°3815
uttaresh
The Penguin Master
Posted on 03-12-2009 at 09:25:16 PM
Your best bet would be to create your required program in Visual Studio or some other application development platform. Be forewarned, though: unless you are extremely well-versed in a language, you will not be able to manipulate the more advanced imaging options (like anti-aliasing and blurs). Thus, your output would be of an inferior quality.
One forum at a time.
n°3816
Callum76
Posted on 03-13-2009 at 12:13:28 AM
thanks the same
bye
