25 unknown users
Gimp Tutorial - Make a G2 Tux
n°2931
ValHolla
Posted on 10-17-2008 at 05:10:46 AM
This is a tutorial for creating a G2 Tux using The Gimp.
I started off using Overlord's Template and the tutorial for a G2 Tux using The Gimp in French..
Since I don't speak, -- or read French --  I ran the tutorial through Google Translate
I have re-created the procedure and simplified it.  The tutorial is still a very long one.
I wrote it in a way that if someone gets ambitious they could create a script-fu to generate the image automatically.
I don't have a site right now to post the images,  so I wrote the tutorial in OpenOffice.org  and exported it to a PDF file.
Here is the Template I used for the Tutorial: G2_Tux_Gimp_Template.xcf
Here is the Tutorial: g2_gimp_tutorial.pdf
n°2932
ValHolla
Posted on 10-17-2008 at 05:28:14 AM
Here is the Final image in xcf form. G2_Tux_Final.xcf
n°3487
Hari Seldon 2
Posted on 10-31-2008 at 01:56:24 PM
 merci :great:  :great:
n°3489
codenamem2k
Posted on 11-01-2008 at 11:25:00 AM
Good tutorial dude:)
I am using PS though;)
