23 unknown users
[Gimp Tutorial] Foil in Gimp
n°2917
Snobulls
Posted on 08-16-2007 at 09:36:12 PM
I am new at making tutorials and i want to make this perfect.  :great:
finishing project should look like this. http://i157.photobucket.com/albums/t57/snobulls/FoilPaper.png
1. Make a canvas size. I took 800x600.
2. Then choose your gradient tool and choose white to black or dark grey. http://i157.photobucket.com/albums/t57/snobulls/GradientOptions.png
3. Then click around on your canvas a bit. About 50 times.
4. Go to filters -> Distort -> emboss. Mess around with settings until you get it just right.
Final product - http://i157.photobucket.com/albums/t57/snobulls/FoilPaper.png
Thanks for reading my tutorial. :party:
n°2918
Posted on 08-17-2007 at 06:45:41 AM
That's very good effect :oui: , I can't imagine how wonderful would it look when blended with different colors :loveit:
BTW , Welcome to crystal XP :party:
n°2919
Posted on 08-17-2007 at 09:47:00 AM
Welcome to CrystalXP and thank you for the tutorial! :loveit:
n°2920
Sodaplayer
Posted on 08-28-2007 at 12:37:22 AM
Great result but it's not that clear.
n°2921
Posted on 08-28-2007 at 08:05:36 AM
What do you mean with that?
n°2922
churka07
Posted on 08-28-2007 at 04:44:13 PM
Im having problems with this tuturial, i really want to do it though
I can do it, i just dont know how to make it glossy and shiny like yours
And What is a Canvas?
Maybe thats where im messing up
n°2923
Posted on 08-29-2007 at 01:29:03 AM
Canvas is the area of a program where you work and draw :ar: in tutorial , it means that you have to make a document having size 800 by 600 px , I don't think that's the real cause of your problem :neutral:
n°2924
sosoe222
Posted on 08-29-2007 at 08:35:13 AM
Don't you think this tutorial is a bit too short and it should have something more added? :neutral:
n°2925
Clarkieboy
Posted on 10-03-2007 at 03:55:36 PM
Yep. But thanks for tutorial. Its a short alright,but its well explained.  And BTW I learned something.
:boulay:
n°2926
Clarkieboy
Posted on 10-03-2007 at 04:20:55 PM
I think that the picture is better like this.   :oui:
I have just selected the color gradient and...
Then go to filters>distort>waves
I think that this effect is much better.
What do you think?
http://one.fsphost.com/forcxp/1.jpg
n°2927
fixiale
Posted on 10-22-2007 at 12:02:02 PM
It's his first tutorial, and a good one. I understood it anyway.
n°2928
blingonmywrist
Posted on 11-05-2007 at 04:27:07 AM
very neat effect. goodjob on the tut for a first! :great:
n°2929
hammdo
Posted on 11-20-2007 at 05:41:35 PM
OK, I figured out what's happening here.  Here are the steps I took
First I just started with a new image --  set @ 420 X 300 pixels, advanced options 'Transparency'
Next in the ToolBox dialog, I chose (or clicked on):
Gradient Tool
Then I chose the Gradient 'Metallic Something'.
Look @ the Gradient Options and make sure your 'first' selection is 'Mode:' Normal
Then, use the gradient tool in the image (move gradient from top to bottom) I use CTRL then left mouse button to drag a straight line.
Once you've done that, go back to the ToolBox dialog, and change the Gradient 'Mode:' to Difference.
Go back to the image and 'click' in the image as many times as you want (I did about 10).
NOW, you can go to the 'Filters' menu item in the Image dialog, and select
Filters->Distorts-Emboss
My settings are:
Azimuth 58.24
Elevation: 41.03
Depth: 11
It looks more like foil that way...
Here, you can play with the settings and change it a bit (in the Emboss dialog)
Hope that helps!
-Don
n°4073
Ex1
Life is awesome, you should try it?!
Posted on 05-27-2009 at 11:26:49 PM
well, nice result but its not a real tutorial to me ><'
Just tells us to add one filter and done?... naah.. 3/5 stars ^^'
(big stars for the try and the fact that its your first)
http://i42.tinypic.com/20gk4kg.png
n°4403
manufan4life
Posted on 11-27-2009 at 06:51:03 PM
its a good tutorial
i definatly use it now
thyanks
n°4548
Ikmalhidayat
Ikmalhidayat Windows 7 User
Posted on 06-09-2010 at 07:08:20 PM
This mine.
http://www.crystalxp.net/forum/mesimages/343817/Folded.png
I dont know how to say... Well, you suggest.
http://www.crystalxp.net/forum/mesimages/343817/IkmalhidayatSignature3.png
n°4549
Posted on 06-10-2010 at 05:05:49 PM
Nice! :)
Follow me on Twitter | Visit my website.
n°4550
Ikmalhidayat
Posted on 06-10-2010 at 11:10:02 PM
Thank You!
