sungeab45 and 14 unknown users
My 1st PhotoShop Work
n°13119
kaibaman
Posted on 03-30-2009 at 06:39:58 PM
Hey Guys I'm new as u can see......
I'M A GRAPHIC NOOP!!!  :ohwell:
That is my 1st work with photoshop!!!
i wanna to shw u what have i done!
The Avatar:
http://img217.imageshack.us/img217/3908/avatarcopy.png
hope to get comments :)
n°13121
Posted on 03-30-2009 at 08:33:46 PM
Welcome to CrystalXP kaibaman. :D The most important thing you need is creativity and a strong will to continue practising. The skills will follow later. ;) I think you can try to improve the borders of this one a bit. :yes: But it's a good start.
n°13123
kaibaman
Posted on 03-30-2009 at 11:07:03 PM
thx
all i need now how to learn the graphics from A to Z and i know that maybe take the whole life :D
but really i wanna be a designer now!!
n°13126
Posted on 03-31-2009 at 02:07:59 PM
pretty nice result for first attempt :) go through different tutorial sites through google and bookmark your favorite one.You can not grow to the status of a good designer in a moment, you need determination and a lot of time to spend to gain experience in this field :yes: good luck
Igloo <---> DeviantArt
n°13140
.drago.
I am ALIVE!
Profil: Top Penguin
Posted on 04-01-2009 at 10:31:01 AM
nice one kaiba, you may use some effects inside the avatar
and there's a lot of website tutorials you can search on google or ask the forum to give you some links for good tutorials ;)
n°15578
inciongzug
Posted on 12-14-2011 at 06:50:13 PM
In the past, if this came to fax needed presently there weren't lots associated with facsimile options. You can either needed the facsimile device, or else you needed to operate to the nearby duplicate shop and also have all of them deliver your record for you personally. Not too any longer. There is a brand new facsimile alternative, net fax. Internet facsimile lets you leave behind the requirement for the classic fax device. Which means that when you don't personal one particular, no dilemma. In case you don't want to go by way of the irritation of obtaining somebody having a classic device that you may use, absolutely no difficulty. It is possible to nonetheless simply fax paperwork from the comfort and convenience of the personal property. How's this particular possible you may well ask? Straightforward, by using the internet.
Internet facsimile permits you to deliver or even obtain documents on your pc in order to or from the regular facsimile device. To transmit all of them over the net, you very first need to sign up along with an online facsimile support (OFS). You can spend the monthly fee, but it is commonly rather reasonable; normally less compared to $10.00 a month with regard to 500 faxes or even additional. This works away to become regarding 2 pennies for each fax or even less. The OFS is the link which links your own laptop or computer to the fax machine. Let's suppose you wish to deliver a record. You don't have a fax device, but you'll want to send it to an individual that does have the 1. All you need to perform is attach the actual document that you desire to deliver to an email. Then your e-mail will go to the OFS. There it's converted after which sent upon towards the facsimile device from the individual you are sending it to.
People which have fax machines and copiers may also send you document despite the fact that you don't possess one. The actual OFS that you simply sign up along with will provide you with the fax number that you can then tell people. It looks just like a normal facsimile number, however after these people type within the quantity as well as deliver the actual record using their machine, it goes to the OFS, exactly where it can be converted after which sent onto a person. The record may appear to you within an e-mail being an connection. The actual whole approach is fairly slick. The fantastic thing is the fact that because much as the other person using the classic machine is worried, anything is actually absolutely typical. They obtain faxes from their device just as when they had been becoming delivered by a regular machine, plus they send all of them from their device just as when they were sending this to some classic fax device.
In search of more facsimile selections? Nicely you've located an awesome one in world wide web fax. It could be exceptionally low-cost, extremely handy, and very best of; you don't require a fax machine.
Robby has helped quite a few men and women understand regarding on-line facsimile. For far more information, strategies, and tips upon various facsimile alternatives check out his internet site Online Facsimile Support Central. You will additionally obtain a fantastic device there that will allow you to evaluate on line facsimile services.
live music
buy diablo 3 gold
best mmorpg 2011
