legace and 38 unknown users
[Ghost] My first 3D stuff (AoI)
n°11948
ghostnatyphon
To die would be a great adventure.
Posted on 11-08-2008 at 11:36:10 PM
After Truth made a little kennel using AoI, I decided to once again traipse through the 3D world, testing the water, and decided to start with Art of Illusion, instead of Blender :p Here are my first two models, mostly just to test as I learn new skills like texture editing, lighting, boolean modelling and everything else there is to learn  :he:
Hourglass (First render ever! :D ):
http://i184.photobucket.com/albums/x1/darthsmall9/First_HourglassFIX.png
Dice (While looking at boolean and textures):
http://i184.photobucket.com/albums/x1/darthsmall9/WoodDiceMarblePlinthFIX.png
There is a God :ar: www.ie6nomore.com
Glomping the internet populace http://fc02.deviantart.com/fs48/f/2009/196/0/f/0f93b76ffd0ce94dcd8f1041c69e8b42.gif One forum at a time.
n°11949
.drago.
Leaved this forum for a bit!!
Profil: Top Penguin
Posted on 11-09-2008 at 12:14:54 AM
Very nice for the begaining
n°11951
Tanshin
Posted on 11-09-2008 at 01:12:56 AM
Quite nice... I think that something could be done with the texture of the second one... but still excelent
http://i15.photobucket.com/albums/a398/saladbar1/snowleopardbar.png
Glomping the internet populace. http://fc02.deviantart.com/fs48/f/2009/196/0/f/0f93b76ffd0ce94dcd8f1041c69e8b42.gif One forum at a time.
n°11953
uttaresh
The Penguin Master
Posted on 11-09-2008 at 06:25:11 AM
There is a lot of aliasing. Shame on you! :p
n°11955
truth
Posted on 11-09-2008 at 06:56:13 AM
Very Good.
you're picking up fast.The glass in first one looks very nice.
Here are some hints about further enhancements :
  • AoI doesn't comes bundled with plugins.
  so, open the script and plugin manager (menubar>Tools>script and Plugin manager)
   click Install tab and select:
 :ar: Advanced Renderer
 :ar: Preview plugin
 :ar: Display mode icons
 :ar: Look and feel
 :ar: Measuring tool
 :ar: Electric wax theme.
 :ar: Poly mesh
click install selected.
This results in better GUI, and usability.
Message edited by truth on 11-09-2008 at 06:58:05 AM
http://img504.imageshack.us/img504/108/sigglassms3.png
n°11958
Posted on 11-09-2008 at 09:44:56 AM
Nice start. If you install the plugin 'Advanced Rendered', you might be able to increase the quality of your renders. Although that means a longer render time of course. ;)
n°11959
legace
Posted on 11-09-2008 at 11:33:39 AM
Good start Ghost :)
n°11971
ghostnatyphon
Posted on 11-09-2008 at 08:59:50 PM
I'm very annoyed and confused about the aliasing, I had the Advanced Rendering and aliasing set to maximum, it certainly didn't have all that aliasing when it rendered in AoI :/
n°11973
Tanshin
Posted on 11-09-2008 at 10:27:51 PM
Sometimes I notice it happens more when it is on different backgrounds... that is why I usually have a gray layer in photoshop just to make sure there is as little as possible
n°11977
uttaresh
The Penguin Master
Posted on 11-10-2008 at 10:33:51 AM
There's your problem right there. You need to set ANTI-aliasing to maximum and aliasing to minimum. :o
AND FOR GOD'S SAKE CHANGE YOUR NAME BACK TO GHOST!!!
PS - I know we're not supposed to use CAPS, but I wanted to make it sound like I was crying it out.
Message quoted 1 times
Message edited by uttaresh on 11-10-2008 at 10:35:23 AM
n°11980
Tanshin
Posted on 11-10-2008 at 05:28:32 PM
Well his name is Ghost Typhon on Deviantart... so it does make sense
n°11983
Posted on 11-10-2008 at 06:45:43 PM
that's really a good start :yes: follow uttaresh's suggestion which I am sure about will solve the aliasing problem ;)
Igloo <---> DeviantArt
n°11990
ghostnatyphon
Posted on 11-10-2008 at 09:56:27 PM
1) There is no ANTI-ALIASING option. There is Aliasing, that is it. And if the render is smooth, the saved image should be the same, after all it's rendering an IMAGE and showing me the IMAGE, why should it save at a low quality?
2)And I can't change my name, the name I registered with was ghostnatyphon, however on the old forums I was able to set my user name as it was seen on the forums to .Ghost. This is no longer available, and so I must live with my name :(
Message edited by ghostnatyphon on 11-10-2008 at 09:56:37 PM
n°11994
uttaresh
The Penguin Master
Posted on 11-11-2008 at 07:56:38 AM
Ask an admin then.
n°12000
truth
Posted on 11-11-2008 at 02:26:55 PM
Are you sure you using Advanced renderer ?
http://www.crystalxp.net/forum/mesimages/145180/AA-max.png
there is an antialiasing option, and it saves your image in real time, right from the instant you click render
button.
Read the manual
n°12009
ghostnatyphon
Posted on 11-11-2008 at 09:43:05 PM
I have that on maximum! I thought it said Aliasing, not antialising :p
Anyway I definitely have that set to MAXIMUM.
Anyway I don't know, I'm sure next time it'll be fine, usually with me after finding something didn't work as expected it just goes ahead and fixes itself, making me look a fool :p
n°12017
thetmyster
Profil: Top Penguin
Posted on 11-12-2008 at 04:38:09 PM
I like The Wood Block  :yes:  but possibly a little shine ?
http://www.crystalxp.net/forum/mesimages/298907/Sig%20No%20bars%20%20%20copy.png
Glomping the internet populace.http://fc02.deviantart.com/fs48/f/2009/196/0/f/0f93b76ffd0ce94dcd8f1041c69e8b42.gifOne forum at a time.
n°12436
Aqua Crystal
Posted on 12-26-2008 at 10:49:31 PM
Cool. However the dice one looks a little funny. Like the hourglass though! :great:
http://i548.photobucket.com/albums/ii343/AquaOrb/Aquasignature.png
My Blog
n°12437
ghostnatyphon
Posted on 12-26-2008 at 11:30:41 PM
Thanks :) I really need to do some more :/
Message edited by ghostnatyphon on 12-26-2008 at 11:30:52 PM
n°12617
rapoupoul
Posted on 01-26-2009 at 04:28:24 PM
for the 2th one I think you should put a litel less reflection and add bump to it
(sorry for my english)
http://www.crystalxp.net/forum/mesimages/238643/Nima3D signature.2.png
www.brownchicken.weebly.com
