Windows Customization & Support : jimmorgan and 18 unknown users
Help, true transparency (in spanish)
n°10843
snorzsnorz
Posted on 11-12-2008 at 04:33:51 AM
Hola, ¿existe alguna forma de que solo funcione el truetransparency en forma normal?, es decir, que no funcione en forma maximizada.
Gracias de antemano
In inglish(with translator)
Hello, is there some way that only operate in the normal way truetransparency?, That is, is there a way that the program will not work in a maximized?.
Thanks
n°10845
Neil
Posted on 11-12-2008 at 07:50:47 AM
Thanks
Hi snorzsnorz and Welcome to Crystal XP :loveit:
I'm not sure whether that is possible since the TT source cords support bot 'Normal' & 'Maximized'  :oui:
Update* I'm afraid there's no such way  to use TT only in normal windows :non:
Message edited by Neil on 11-12-2008 at 07:51:19 AM
n°10856
snorzsnorz
Posted on 11-12-2008 at 07:52:10 PM
n°10866
Neil
Posted on 11-16-2008 at 12:16:33 PM
You're Welcome :loveit:
