18 unknown users
HELP PLEASE
n°10792
aczarnow
Posted on 11-04-2008 at 10:48:53 PM
i just accidentally right clicked and clicked on "quit" and now i cant figure out how to get the rocketbar or whatever its called back :(
n°10795
uttaresh
The Penguin Master
Posted on 11-05-2008 at 05:30:44 AM
Restarting your computer should bring it back.
One forum at a time.
n°10968
Brandon11185
Posted on 12-19-2008 at 05:15:44 PM
But for future reference, its found in the C:\WINDOWS\Bricopacks\[packagename]\Rocketdock folder, along with all the others programs that you choose to install.
n°10970
Neil
Posted on 12-19-2008 at 05:45:00 PM
Thanks for the helping hand Brandon11185 :loveit:
:info: You can also enable/disable the applications of bricopacks (From Crystal Clear upwards via [bricopack name]config) ;)
Message edited by Neil on 12-19-2008 at 05:49:12 PM
