Well, don't know if you can post your own... but certainly other people can suggest sites he might want to try:
http://stor.thetmyster.com/
Very good uploader, multiple upload, unlimited space - it's the only one I ever use!
It also extracts zipped files, produces thumbnails and [img] tags (The amount of time that has saved me!) uses custom folder system for organisation, and allows files of up to 10mb
Message edited by ghostnatyphon on 08-25-2009 at 09:49:54 PM
