Hekifax and 13 unknown users
turntabels
n°10904
y1n14i11
Posted on 11-27-2008 at 09:17:50 PM
my problem is i want that the tabels turns
but i dont know how i shoud do this
http://www.crystalxp.net/forum/mesimages/304395/Needle in the shadow.jpg
enyone can help me??
Message edited by y1n14i11 on 11-27-2008 at 09:40:49 PM
n°10905
Xylar
"eaeaeaewwww FOLLOWING time!"~LAMP
Posted on 11-27-2008 at 09:56:38 PM
are you using photoshop? if you are, then, press 'ctrl -(minus)' twice to shrink the view of the picture.
after that, make the canvas size bigger:
http://i255.photobucket.com/albums/hh145/Projectus/Pic1.png
http://i255.photobucket.com/albums/hh145/Projectus/Pic2.png
then press 'ctrl a', 'ctrl c', then click the button in the pic:
http://i255.photobucket.com/albums/hh145/Projectus/Pic3.png
and 'ctrl v'. then press 'edit-transform-rotate.' (Use pic 4 if your stuck)
http://i255.photobucket.com/albums/hh145/Projectus/Pic4.png
then rotate so it's level.
Pic 5
and your done (hopefully this is what you meant.)
n°10906
y1n14i11
Posted on 11-28-2008 at 07:08:52 AM
at first thanks for your help
but  i mean only this with zhe red X
http://www.crystalxp.net/forum/mesimages/304395/Needle in the shadow Kopie.jpg
n°10907
meisterfdark
3.141592654...
Posted on 11-28-2008 at 11:14:26 AM
You want to animate the disk??? :tongue:
n°10908
meisterfdark
3.141592654...
Posted on 11-28-2008 at 11:22:36 AM
You can use the "finger-smudge" Tool .
i did it and got this:http://i204.photobucket.com/albums/bb302/Meisterfdark/Needle-in-the-shadow-1.gif
its not really good because of my fastness* try it!
*is that a speakable english word i don´t know because i´m german^^.
Message quoted 1 times
Message edited by meisterfdark on 11-28-2008 at 11:38:40 AM
n°10909
y1n14i11
Posted on 11-28-2008 at 02:51:12 PM
like me lol^^
German:
jo hat ich vor das zu animieren aber ich brauch die bilder einzelnt weil ich das in einen player reinbaue und das geht nich als gif^^
danke für deine hilfe
English:
yes i want to animate the disk^^
thanks for the help
Message edited by y1n14i11 on 11-28-2008 at 02:53:17 PM
n°10910
meisterfdark
3.141592654...
Posted on 11-28-2008 at 04:04:01 PM
thats possible (give you the frames) but thats only two!
Here you go:
Frame1:http://www.crystalxp.net/forum/mesimages/251101/Needle-in-the-shadow_frame_0001.jpg
Frame2:http://www.crystalxp.net/forum/mesimages/251101/Needle-in-the-shadow_frame_0002.jpg
Wfg:Meisterfdark
Mfg:Meisterfdark
n°10911
Posted on 11-29-2008 at 04:08:23 PM
This is not a tutorial, and because of that, it is in the wrong place. :yes: I'll move it to a more appropriate place. :ange:
Topic moved.
n°10922
codenamem2k
Posted on 12-02-2008 at 08:41:27 AM
i did it and got this:http://i204.photobucket.com/albums [...] adow-1.gif
Good result man :great:
n°10957
y1n14i11
Posted on 12-13-2008 at 10:30:24 PM
ok guys thanks for your help  :wink:
i have found another solution
http://img2.abload.de/img/tbdesk2kopie0r9o.png
i have create my on disk and now i´m tring to animate this picture^^
Message edited by y1n14i11 on 12-13-2008 at 10:35:27 PM
Bad English because German^^
http://www.abload.de/img/ballpsigvdfv.png
