22 unknown users
I Don`t Know if i can ask this
n°11610
xanderneko
Posted on 07-01-2009 at 08:32:58 AM
can i ask some Tuto... How to Create a animated sig... like the transformer text breaking apart..
n°11611
ghostnatyphon
To die would be a great adventure.
Posted on 07-01-2009 at 09:16:46 AM
There are some animation tutorials already on the site, in the tutorials section, so you might want to do some searching
For this specific help, what program are you using to make the animation? i.e Photoshop , TheGimp, Fireworks, Flash, and what version of the program.
Let us know that, and then we'll be able to help :)
There is a God :ar: www.ie6nomore.com
Glomping the internet populace http://fc02.deviantart.com/fs48/f/2009/196/0/f/0f93b76ffd0ce94dcd8f1041c69e8b42.gif One forum at a time.
n°11615
xanderneko
Posted on 07-02-2009 at 08:55:49 AM
well im using photoshop... and CS 2 version.... i did some searching... but i dont see anything about text to breaking apart
n°11616
Posted on 07-02-2009 at 04:58:19 PM
Achieving such a text effect won't be possible in PS since it's 2D.I think only a 3D animation program can be used to make such effect.
Igloo <---> DeviantArt
n°11727
DeadHouse
Posted on 07-24-2009 at 04:56:19 PM
Use Video Avatar, it's much easier than Photoshop or smth else
