12 unknown users
Help
n°446
4.9
Posted on 07-05-2006 at 07:42:46 AM
I'm using Photoshop 4.0, and I need to know how to transform a selection, without distorting the image.
n°451
vIcO
Posted on 07-05-2006 at 11:15:37 AM
I don't use Photoshop 4.0 ( :oh: ) but I think you can clic on a padlock or press Shift during transforming the selection  :wink:
n°456
Neil
Posted on 07-05-2006 at 09:08:04 PM
Is there anything like 'transform selection' in Select sub menu??
If not you can press Ctrl+T to transform your selected area of an image or go to Edit>Transform>
I'm using Photoshop CS2 (9.0) so some of the ways may not be achievable for you :wink:
And 5.0, your avatar has aliasing effects around, I think you can edit them to get more likely one :smile:
n°780
d,st
Posted on 08-15-2006 at 05:41:42 PM
use the original tut
