| C1oud Profil: New Penguin | Hi folks, well, I have to admit, that I'm a bloody n00b according to this whole design thingy and I'm so sorry to provide mental pain for you by this question, but I greatly appreciate what you are doing here. It's awesome  So... ehm... I've just downloaded the visual style 'Vista CG' and am too dumb to implement it in my windows XP by my own. Help  | |
most likely it's a visual style for Window Blinds XP, try downloading Stardock's Window Blind's XP, that should work. from www.stardock.com | |
Xorios Profil: Penguin Pro | | |
C1oud Profil: New Penguin | Woohoo, awesome, it worked ! Thaaaaank you !  | |
Draginol Profil: Penguin Pro | Quote :
Visual Styles are only made for XP without any external apps like WindowBlinds or StyleXP. WindowBlinds skins/thems have the extention .wba Thanks  | |
Neil Chances are not had but gained....... Profil: Penguin Pro | Quote :
Correct  But when you're installing 3rd party visual style (not a one developed by Microsoft), your original uxtheme.dll won't allow you to change the theme  therefore, you'll need to patch the .dll  StyleXP and Uxtheme Multipatcher (also Neowin version) are the patches avalable in the net but Style Xp is just not only a patching devise. If you want, you can use a Visual style (msstyle) in Windowblinds, but first you have to convret that in to a wba using Skin Studio  | |
Forgot to mention that slight detail... | |
Neil Chances are not had but gained....... Profil: Penguin Pro | Yes and Skin studio is to develop wba skins (theme packs for Windowblinds. (like I've mentioned earlier ) | |
