7 unknown users
The Pen Tool
n°379
Phactor
Posted on 06-08-2006 at 10:30:00 AM
As i was working on the "Make a B&B icon" tuto, i just could not figure out how to get that pen tool to work right, to get the clean line like in the photo.
http://kmillio.crystalxp.net/bnb-tutorial/10.jpg
are there tutorials on this tool?
n°380
Narco
Profil: Modo
Posted on 06-08-2006 at 10:41:20 AM
There are actually 2 tutorials about this tool, but they are in french :ouch:
First tutorial (by k-net)
Second tutorial (by Tet_de_champ)
n°381
Neil
Posted on 06-08-2006 at 11:58:22 AM
Actually, working with the Pen Tool in Photoshop is an easy task.
SO here I'll give you a quick tutorial about how to create that path in creating B&B icons by k-millio.
First, select the 'Pen tool' from the toolbar.
http://img112.imageshack.us/img112/1301/pen4fc.png
And make sure to select the 'Path' option from the Options window
http://img162.imageshack.us/img162/3628/paths8pd.png
Then first of all you need to create a starting point tostart your path. so click on a point like a in your design model
http://img240.imageshack.us/img240/2258/018lx.png
(it doesn't matter whether the point is over the Canvas since what is important here is
the part of the path which go over the layers)
After you've created the starting point move your mouse to a place like b in the window and click. But don't release the left-mouce button!!
After you click on point b, click and drag the mouse point till you see the curve is like this.
( Tip:*follow the direction of the silver arrow :wink: )
http://img103.imageshack.us/img103/49/025fv.png
Note:*dragging after creating an anchor point with Pen tool will curve the area between the last two points :smile:
Then, click on a point like c and curve the line between b & c
(Here, move the mouse pointer to the direction given by the red arrow)
http://img103.imageshack.us/img103/2310/032ep.png
Then the path is already completed for the B&B icon. :smile: But to make a selection you need to complete the loop as a shape (to select an amount of pixels)
So just make some points in places like d, e,& f to avoid the path from running over the picture layers twice. then Finally overclick on point a to close the spine.
http://img108.imageshack.us/img108/1996/045jt.png
Now your path is completely finished and all you need to do is to make the selection. K-millio's tutorial will guide you through the rest of the designing. :oui:
When you delete the selected area of the White to Transparent gradient layer (probably Layer 3) The design will look like this :xeyes:
http://img103.imageshack.us/img103/3593/final2te.png
Note:*This may not seem like the original path but my idea was to give the instructions in creating such :oui:
Edit:* And after you've completly followed this tutorial you can improve your skills by creating your own B&B icons like this done by me (after writing your tutorial)
http://img68.imageshack.us/img68/1457/neil67sf.png
n°382
Phactor
Posted on 06-08-2006 at 07:34:49 PM
This is great Neil :great:  Thanks so much. gona go try it now :smile:
n°383
ZaKaR
Profil: Top Penguin
Posted on 06-08-2006 at 07:39:17 PM
Your mini-fast-nice-tutorial is awesome , very good job neil , perfecto  :sarcastique:
n°384
Phactor
Posted on 06-08-2006 at 08:25:08 PM
Neil you are da'man! thanks so much bud!
heres my Icon :smile:
http://img.photobucket.com/albums/v233/BigJim101/bf1a8ca7.png
n°385
Azzurra
Posted on 06-08-2006 at 08:27:11 PM
nice job neil once again :great:
Phactor you have a nice result :biggrin:
n°386
Neil
Posted on 06-08-2006 at 09:12:39 PM
Thank you all for the appreciation Azzurra & ZaKaR :loveit:
And Phactor, Nice work :cool: Didn't I tell you that you can improve your skills after the tutorial :biggrin:  K-millio's (he's reading this right now :kiss: )
n°721
de lioncourt
Posted on 08-09-2006 at 01:59:40 PM
Awsome Tutorial Neil!
Exactly what i needed! Thanks once again!
n°725
Neil
Posted on 08-09-2006 at 06:54:11 PM
You're Welcome de lioncourt :loveit: and I'm looking forward to se your result in the releventy thread :oui:
n°735
Draginol
Posted on 08-10-2006 at 11:58:22 AM
+ 1 :wink:
n°753
d,st
Posted on 08-12-2006 at 05:09:35 PM
another one Neil wow
nice job
n°755
Neil
Posted on 08-12-2006 at 09:26:39 PM
Thanks Y$F
n°759
Draginol
Posted on 08-13-2006 at 07:44:58 AM
nice job
:lol: Nice summary Y$F
