Hi mkouk
I think the easiest way to add a logo to a tux is this:
1. Open the tux. ( In Photoshop...)
2. Then go to File
Place
then select the logo you want to add.
3. Rezise the logo so that it fits, and then place it wherever you want, by clicking inside the box that appears around the logo, so that you can drag it to the position you want.
Here's my result:
i guess i am just too rubbish at photoshop!
Don't worry, everybody has to start somewhere, I'm sure you'll learn more in Photoshop as long as you keep trying...
