10 unknown users
I don't now how go on...
n°305
klok75
Posted on 04-14-2006 at 06:38:51 PM
I dont know how make the reflection on the body and the top head of this my buddy.
I've done with eyes, legs, feet... but anything I try with body looko like very bad!
Can someone give me some tips?
Ciao, Nicola.
n°306
Neil
Posted on 04-14-2006 at 09:41:51 PM
:great: Here are some little openions but I strongly hope that someone who is more familiar with Adobe Photoshop will hhelp you.
:jap: It will be beter if you have two different layers for the body and the head top.
select the apropriate layer and go to bevel and Emboss inblending options.
 :oui: First try to get what you need from the above structure parameters
 :oui: then under shading column custamize the appropriate parameters, Here mainly concentrate about the 'Angle' & 'Gloss Contour' then adjust the opasity of the Highlight and shadow or choose a mode (Normal,Softlight etc..)
:lol: Here I'll some of the quantities but I really don't knowwhether they'll suite u or not
:neutral: For Body
style-Inner bevel
technique-smooth
Direction-up
size-90px
soft-16px
angle-60 (use global light)
altitude-30
Gloss contour-65in & 45out (anti aliased)
Highlight-Normal, white (255R,255G,255B) 100%opacity
Shadow-Multiply, (255R,146G,5B) 100%opacity
:xeyes: Sorry about the detailed information because I cannot even attach a picture of what I discussed because of my connection malfunctions so hope this will be useful
:great: :note: also check the defoult styles given in photoshop specially under Glass buttons & Web styles
And also search in our tutorial files for your desire and you might be able to find it.
:penguin: Welcome to Crystal community :penguin:  :loveit:
n°592
d,st
Posted on 07-24-2006 at 10:51:22 AM
Hi guys its me
 :boulay:
What kind of photoshop
are you using :he:
What kind of photo shop are you using 2.0/ 3.0 /4.0
n°597
Neil
Posted on 07-24-2006 at 12:19:08 PM
I'm using Photoshop CS2 (version 9.0) :oui:
n°598
sexbox
Posted on 07-24-2006 at 02:46:16 PM
:oui:
n°654
d,st
Posted on 08-05-2006 at 01:22:30 PM
Thanx maybe I will buy one:great:
n°656
Neil
Posted on 08-05-2006 at 07:16:40 PM
Yes you should It's great flexibility
 :wink:
n°657
Draginol
Posted on 08-06-2006 at 09:19:59 AM
+1 :wink:
Photoshop is awesome, the most powerful program I have ever used.
