| xCeres Profil: New Penguin | Whats more easy to learn and noob-friendly? And what is more efficient and is it what you use? | |
Frozzn Profil: New Penguin | I use Photoshop CS 3 (I bought it one week after Photoshop CS 4 camed out ). I think the're about similar. But it's really very difficult to learn it, but if somone has good ideas . | |
TheVestel PHP Programmer Profil: Big Penguin | What's the name of you design teacher?  | |
Hey, I think adobe has a free upgrade plan for people who bought at times like that, at least they usually do... I'll have to dig. CS2 and CS3 are quite similar, I really can't say which is easier to learn as I started to learn with CS1 EDIT: Frozzn, it appears you might have just missed the window http://www.adobe.com/go/tn_19582 | |
Yes, I heard something about that as well once before. Did you buy the software online from Adobe or in a shop (Apple retailer, software shop, etc.)? You can try to contact them.  | |
uttaresh The Penguin Master Profil: Penguin Pro | Well, I just bought CS3 some time back, and I have to say it just FEELS better. I don't know what that means, but it just does. | |
R a b i D Profil: New Penguin | Cs3 Cs2 has some error: start-up slower than Cs3, etc | |
Frozzn Profil: New Penguin | I've bought it in a softwareshop in my village. What's actually new in Photoshop CS4? I think it has advanced 3-D options . I will contact Adobe . | |
Gruzz Profil: Moderator | Here's a list of new and enhanced features Adobe has introduced in Photoshop CS4.  | |
