Windows Customization & Support : saab and 19 unknown users
how to make an old paper?
n°3096
tassam
Posted on 10-11-2008 at 04:06:40 PM
so how to make an old paper like these?
http://dezignus.com/wp-content/uploads/2008/01/old-paper-dez.jpg
esp the edges please ^^
thanks
n°3109
Posted on 10-12-2008 at 03:52:14 PM
The edges are complex but can be designed my using suitable tool like 'Pen-Tool' :oui: the overall shape of the paper can be made in PS however the pattern and coloring will require some more time and attention :wink:
n°3110
uttaresh
The Penguin Master
Posted on 10-12-2008 at 04:21:40 PM
Yeah, that takes time and patience ... and skill too!  :oh:
But you can get a quick job like this in under 5 minutes. :wink: Just make more cuts and folds in it to get the above. :tongue:
n°3120
tassam
Posted on 10-16-2008 at 01:14:20 PM
Uttaresh can you tell me what pattern you used in that?
n°3129
codenamem2k
Posted on 10-18-2008 at 01:05:19 PM
It just seems like a radial gradient... And also, he have used the page curl tutorial, which is posted in the graphics tutorial section :wink:
n°3130
Posted on 10-18-2008 at 01:38:43 PM
It's definitely not a plain radial gradient. :angel:
n°3131
Posted on 10-18-2008 at 03:04:29 PM
I think inner-shadow has been used on that paper instead of radial gradient :oui: for the pattern , just make a layer and use noise filter on it , now set the Blending-Mode of the layer to Overlay/SoftLight :wink:
