14 unknown users
how and where to upload .psd files?
n°3095
tassam
Posted on 10-11-2008 at 03:43:18 PM
does any site provide uploading files in free?
i only want to upload .psd format file?
thanks -  :boulay:
n°3097
Posted on 10-11-2008 at 05:23:32 PM
Did you try to look on Google before you asked you question? :angel: Here and here are some more popular ones. :oui:
n°3098
tassam
Posted on 10-11-2008 at 05:38:57 PM
uh! sorry *sweat*
thanks ^^
n°3116
codenamem2k
Posted on 10-15-2008 at 03:20:57 PM
I would prefer ImageShack[http://www.imageshack.us/]
n°3117
Posted on 10-15-2008 at 04:03:48 PM
You cannot upload .psd files to ImageShack. They allow the following formats: .jpg, .jpeg, .png, .gif, .bmp, .tif and .tiff. :smile:
n°3118
Posted on 10-15-2008 at 04:12:51 PM
If you want to upload large psd files then I would suggest you to compress them as rar or zip files and then upload them to mediafire.com :smile: the compression considerably reduces the file size :oui:
n°3119
uttaresh
The Penguin Master
Posted on 10-15-2008 at 04:17:53 PM
I just upload them here. :he:
