16 unknown users
How to make the edges blunt.
n°3030
GOKOOL
Posted on 10-02-2008 at 09:04:12 AM
Hi! guyz plz tell me me how to make the edges of an image blunt using photoshop(CS2).
n°3031
Posted on 10-02-2008 at 09:07:27 AM
I'm not sure what you mean. :neutral: Perhaps you can provide an example image. :smile:
n°3035
GOKOOL
Posted on 10-02-2008 at 09:17:39 AM
Here is an example.This image has sharp edges and i need to make the edges blunt as you can see in my signature.
n°3036
Posted on 10-02-2008 at 09:21:51 AM
just Ctrl+click on the layer of the image and go to 'Select->Modify->Smooth' put desired value in px and press Enter , now press 'Ctrl+Shift+I' to inverse the selection and hit 'Delete' key :wink:
