18 unknown users
Converting a picture from 2D to 3D
n°2938
martypastor
Posted on 08-10-2008 at 06:31:41 AM
Hello all
I know somehow this is possible but will it be hard?
Can I do this via Photoshop?
Thanks
n°2939
ghostnatyphon
Who Dares Wins
Posted on 08-10-2008 at 12:06:57 PM
If the audience will have 3D glasses you just need two pictures of an object, from slightly different perspective:
PHOTO1>>
----------------------------------------------------::OBJECT::
PHOTO2>>
and then place the pictures over the top of each other, put a red tint over one photo, and a blue/cyan tint over the other.
Put on your glasses and you should have a 3D image.
Otherwise you would need to animate the image and be very clever with it to get a 3D effect.
There is a gimp tutorial for this, I'll see if I can find it.
EDIT:
Here is the gimp tutorial
http://forum.crystalxp.net/index.php?showt...570&hl=Gimp
You could also achieve this using stereograms, though only some people can see them...
http://www.smart-kit.com/wp-content/upload...gram%20bird.gif
If you go slightly bozz-eyed (Not the best way) so that the swans along the bottom merge together, you should see an image form. It is better if you can unfocus, by looking at a point behind the image, then moving the image in front of you but without focusing on it.
If you can do this you should see two swans on the image, and it is amazin when you see it for the first time.
It is very hard to explain though...
This one may be easier:
http://i184.photobucket.com/albums/x1/darthsmall9/stereogram_oi_dots_l.jpg
It is the circles but they appear with some in front, and some behind. You can see the image was made by having the circles at different positions, and when you go bozz-eyed (or unfocus) on the image you should see the circles stand out, an some "stand back".
It is a very good way of producing 3D, though they are hard to make complex ones, and you can't easily turn an existing image into one. Though I believe there is (or was) software that would take an image and make a stereogram of it.
n°2949
headbuster
Posted on 08-12-2008 at 06:45:56 PM
Reported Attack Site!
This web site at www.3dwonderstuff.com has been reported as an attack site and has been blocked based on your security preferences.
Attack sites try to install programs that steal private information, use your computer to attack others, or damage your system.
Some attack sites intentionally distribute harmful software, but many are compromised without the knowledge or permission of their owners.
This is what Firefox says about http://www.3dwonderstuff.com/Images/optica...m_oi_dots_l.jpg  :grrrrrr:
n°2950
ghostnatyphon
Who Dares Wins
Posted on 08-12-2008 at 06:57:58 PM
That's weird, mine shows up fine...
I'll remove the link in case :wink:
n°2951
Posted on 08-12-2008 at 06:59:18 PM
At the moment that link isn't even working at all. :neutral:
The page you are looking for might have been removed, had its name changed, or is temporarily unavailable
n°2952
ghostnatyphon
Who Dares Wins
Posted on 08-12-2008 at 07:02:56 PM
I've removed the link and uploaded the image now :wink:
n°2953
headbuster
Posted on 08-12-2008 at 09:11:50 PM
Thanks  :great:
n°2954
codenamem2k
Posted on 08-16-2008 at 01:13:18 PM
Great piece of information dude... :boulay:
n°2963
truth
Profil: Top Penguin
Posted on 08-20-2008 at 04:48:28 PM
WoW ! that looked amazing. Alternate circles are ahead of others. and the swans fly before a grass layer behind.
the problem is that by nature, our eye-lens automatically focus according to our eyes converge.
so, its little hard to focus on screen while looking behind it.
n°2964
ghostnatyphon
Who Dares Wins
Posted on 08-20-2008 at 05:23:28 PM
It is yes, apparently (Though this may be slightly off) around %10 of the people in the world can't see the images in stereograms (Like the circles and the swans) because it is quite simply impossible for their eyes to focus on it properly.
I remember when I first saw these I had a nagging feeling I was going to be one of those %10 :tongue: I spent weeks staring at pictures and going bozz eyed and got nothing, and then one time I just stared at it and my eyes unfocused by themselves (They do that a lot, might be from lack of rest... they mainly do it when I'm looking at screens liek computer or TV) and suddenly i thought there was something, and bam! all of a sudden I saw a robin on a branch, it was amazing :biggrin:
n°2965
truth
Profil: Top Penguin
Posted on 08-20-2008 at 05:52:00 PM
I agree.
from my experiments, the best way to do so is:
create a stereogram with transparency (like pictures of an object with transparent background ) ,
stick it on a glass window and look out side.
and you will see 3D things floating outside.
(I'll recommend a UFO picture  :lol: )
n°12028
zmz
Posted on 01-27-2010 at 05:26:53 AM
well you could give it the apearence of being 3-d by adding shadow and light affects, but depending on the picture it might take a while
