15 unknown users
need help change my vista theme???
n°2930
blah00
Posted on 07-29-2008 at 12:54:55 AM
i have download it the black vista theme for my XP... i want to keep the same vista theme just change the color of it...when i right on my desktop go to properties then Display Properties....
(Appearance)  by Color scheme.. Aero green or blue dont work when i click apply how can i fix this???  and also when i open folders up its all black of couse i just want to make the black a little lighter how can i do this?  or if there is something i can download for it idk remeber i want to keep my same theme
n°2931
Posted on 07-29-2008 at 09:03:30 AM
Welcome to CrXP blahOO :smile:
It's not as easy in XP to change the color of a theme as in earlier versions of Windows , you will need StyleBuilder to make any changes in the theme , you may also be required to have a graphic editing program like Adobe Photoshop :oui: I would rather recommend you to use some other visual style , you can find a lot of them at deviantart.com :wink:
the same suggestion is recommended for icons :jap:
Have a nice stay :angel:
n°2932
Posted on 07-29-2008 at 04:43:02 PM
Topic moved.
