| IronChefofVaaj Profil: New Penguin | Just wondering if anyone could show me some nifty things I could try and do with text, and not always just typing it..but drawing it I guess? I want to learn to make things like this:  and I want to learn so I can make something cool for my girlfriend so help would be greatly appreciated. uh. Idk if i posted this in the wrong place but if I did sorry.. | |
Asher Genius is not born , it is made.... Profil: Moderator | The text on the image is not necessarily hand-drawn , you can use different fonts for achieving a result of similar quality a lot of them can be found here  topic moved
IronChefofVaaj Profil: New Penguin | Oh thank you, but in the background the curved line.. how did that person achieve that? when i try to draw lines they are never smooth and so elegant looking; they always look choppy and kinda messy.. | |
ghostnatyphon To die would be a great adventure. Profil: Penguin Pro | I suspect they used the pen tool... you could do endless curves with that and then stroke it... oh the evil pen tool  | |
IronChefofVaaj Profil: New Penguin | Oh thank you, I was reading about the pen tool. stupid pen. Its a tough one to get used to.  | |
Asher Genius is not born , it is made.... Profil: Moderator | It's not stupid at all , infact it's one powerful tool of PS , you just need to practice it in order to know its importance  | |
headbuster Profil: Penguin | Hello This might help you! It helped me  | |
codenamem2k Profil: Big Penguin | Ghost... great avatar... And, headbuster, thats a really good tuto on how to use pens Thanks | |
ghostnatyphon To die would be a great adventure. Profil: Penguin Pro | It's not that brilliant, as sadly I can't get the ends of the curves to taper... I've used brush and simulate pressure just like I always do... but different result... I'll have to go back to the vista wallpapers tutorial and check. I made my avatar with help from a tutorial, I'll post the link if I can find it. http://www.google.com/search?client=opera&...-8&oe=utf-8 That's the one, thoug hit wont load in my browser... Opera is very tempermental... But since IE is annoying and FF wont work I have no choice It's not that bad anywho. If it doesn't work try going to the site (www.psdtuts.com) and then locating it that way. | |
uttaresh The Penguin Master Profil: Penguin Pro | Quote :
Actually, I think it's really easy and helpful If you master it, you can use it to make just about any shape you want. Then you can even resize to a much larger (or smaller) size without losing any quality and without getting any aliasing. For example, my Batman tux, found in the link below, was made ENTIRELY with the Pen Tool.  Click! | |
ghostnatyphon To die would be a great adventure. Profil: Penguin Pro | You made that entirely with the pen tool? Minus the crystallisations I suspect  That is truly amazing... I can barely draw lines with the pen tool  It is a hard one to master. | |
headbuster Profil: Penguin | Quote :
Ohh... my!
uttaresh The Penguin Master Profil: Penguin Pro | Well, I did not make the original tux, of course. I mean everything else: The Bat-Suit, his muscles, his cape, boots, mask, ears, etc. And yes, minus the gradients and shadows.  | |
