Exactly how do you make visual styles for Windows XP? Do you use some special software?
And what about these BricoPacks? How do you make a visual style that can change the taskbar etc. and all the icons??
I think I want to make one...
Posted on 07-06-2008 at 03:38:27 AM
Genius is not born , it is made.... Profil: Moderator
Posted on 07-07-2008 at 12:38:42 AM
Making visual styles is not going to be as easy as making icons or other such simple images , it's complex and requires intense patience and determination , you can use StyleBuilder for making visual styles
uttaresh
The Penguin Master Profil: Penguin Pro
Posted on 07-07-2008 at 05:34:30 AM
Thanks for the help! I see it's a trial, though.
Posted on 07-07-2008 at 11:40:22 PM
Unfortunately , it is , the only other way is to use Resource-Hacker or a program of similar nature which is kinda hard
