Windows Customization & Support : saab and 18 unknown users
Creating a Tux
n°2854
slsimpson02
Posted on 06-13-2008 at 07:07:19 AM
Ok, im new to this, and i love the tux. I want to create my own, but i'm not for sure how. I've gathered that you need to use Photoshop, but i'm not a mac user... im windows. Can someone please help me.. as i would LOVE to design my own!!!  Thank you for all the help in advance.!!!  :penguin:
n°2855
earnur
Posted on 06-13-2008 at 07:39:16 AM
First of all welcome on CrystalXP slsimpson02 :smile:
If you want make your own tux, there are tutorials (for G1 and G2 tuxes) and they are made for Windows users :wink: So keep try them and good luck with it :smile:
n°2856
slsimpson02
Posted on 06-13-2008 at 06:22:17 PM
What version of Photoshop should i use? It looks like Photoshop 7.0 is only for mac users? Any suggestions?
n°2857
aqua crystal
Posted on 06-14-2008 at 03:57:09 PM
There are plenty of more recent versions of photoshop and I was never aware that it was for mac users only. The only issue with photoshop is the price tag.
n°2861
slsimpson02
Posted on 06-14-2008 at 06:29:23 PM
no kidding!!!! Im not looking forward to that one!
n°2862
stevenepic
Posted on 06-14-2008 at 09:12:22 PM
There's Photoshop CS, CS2, CS3, and CS3 Extended.
Those are, newer than 7.0. :smile:
n°2864
MaN uTd GuY
Posted on 06-19-2008 at 03:00:24 PM
can you make for me a red G-2 for windows ??  :happy2:
n°2865
codenamem2k
Posted on 06-19-2008 at 06:27:03 PM
You can try the tutorials available in the Tutorials section here :happy2:
n°3140
thetmyster
Posted on 10-21-2008 at 06:23:51 PM
WHY THE HECK DOEEVERYONE THINK PHOTOSHOP 7 IS ONLY 4 MAC USERS I HAV 7.0 AND cs3 !!!! :fouet:
Look this is not ment to be offensive but !!  why would all the vertions before and all the vertions after be for mac and pc and 7.0 not for pc??
http://img530.imageshack.us/img530/8813/lolrk5.png
n°3143
Posted on 10-21-2008 at 07:25:49 PM
There might be some confusion because Photoshop (among other Adobe applications) was for Macintosh only at the beginning. Nowadays they also work on Windows though. :oui: You can still provide your command in a bit nicer way though. :oui:
n°3144
thetmyster
Posted on 10-21-2008 at 07:39:06 PM
SRY BUT ITS THE 15TH TIME IVE SEEN THAT!
OH YES AND MY CAPS LOCK IS BROKEN!
BUT I WILL BE NICER
n°10752
codenamem2k
Posted on 10-27-2008 at 09:55:42 AM
That's not right... I have PS 7 which works on Windows :smile:
