hey guy ! i wrote a tutorial for you ! --- My result: [+] File PSD : Click here to download Password: rabid.li --- And tutorial (2 parts):
Press Ctrl + Alt + Shift + S to save your image as GIF image ! =========================================== Good luck ! --- P.S: srr ! in my tutorial there're some misspelling mistekes (create ! not creat )! In the hurry to write, i wrote wrong ! srr T_T"
Posted on 05-12-2008 at 05:56:36 PM
That's cool R_a_b_i_D! I really like it, I think I will try it later. Oh, if you spend some more time on this I think you can post a new tutorial topic to create something like this. Please use text instead of one/two images for the tutorial though, we appreciate text tutorials a lot more. And don't forget to run your spelling checker over it if you know you make some mistakes.
