18 unknown users
Planet with rings or text?
n°2712
simplyfish
Posted on 04-11-2008 at 12:33:46 PM
Asmodeus hase a great beginners tut. at http://forum.crystalxp.net/index.php?showtopic=33852&hl= for a plantet.
Can anyone share how to add text that bends around the plantet or even rings around the planet?
thank you.
n°2716
Posted on 04-11-2008 at 03:17:33 PM
For a text around the planet I would use the pen tool. Have you got any idea how this works? Make a selection of your planet layer, then with one click you can turn it into a path. After this just grab your text tool and the text will follow the path! :oui:
For the rings, that won't be that easy. Probably you can try to create a path using the pen tool which looks like a ring? :biggrin:
Try the text one first and report how it goes. If you got any questions I'm sure there are several people who can help you.
n°2717
simplyfish
Posted on 04-11-2008 at 10:43:44 PM
I will give it a go tomorrow, I have never done this before so it should be interesting :smile:
n°2718
Posted on 04-12-2008 at 03:29:29 AM
In Photohsop , you can use 'Spherize' filter for making the text look wrapped around the planet , a result similar to the image given below can be achieved through this filter :oui:
http://img258.imageshack.us/img258/231/wrappedqe2.png
For making circles , you can use Pen-Tool or Selection techniques :wink:
n°2719
Posted on 04-12-2008 at 07:48:30 AM
Yup that's right Asher, I was actually thinking as text on top of a circle like in this image:
http://www.cadod.com/Text%20_Circle.gif
:wink: So now you can even choose what kind of text effect you would like.
n°2720
simplyfish
Posted on 04-12-2008 at 10:42:19 AM
Here are two examples.  Iwas just playing around but how can they be improved?
n°2722
simplyfish
Posted on 04-12-2008 at 01:27:12 PM
One more where I combined the swirls tutorial here
n°2723
Posted on 04-12-2008 at 02:54:32 PM
The one with the rings and swirls are actually looking very good! :biggrin: Please try not to make double posts in the future though. Except if there has been a long period of time between the posts. :angel:
n°2724
simplyfish
Posted on 04-12-2008 at 04:05:36 PM
Ok thank you and sorry, just so excited at all the things to try here. :smile:
n°2750
codenamem2k
Posted on 04-23-2008 at 06:59:34 PM
Yeah... great work man... :happy2:
