16 unknown users
Icon set neet needs converting to transparency - how?
n°2706
simplyfish
Posted on 04-11-2008 at 10:07:49 AM
I have a few icon sets for invision but they have cloured backgounds, what is the best way to convert them so they have tranparent backgounds, is there a progam or tutorial for this to make it quick easy but good?
thank you
n°2707
cradłe
Cradle-desktop@ubuntu:~$ whatis windows
Posted on 04-11-2008 at 10:58:34 AM
And what does cloured mean? :neutral:
[C]radle.eXe
n°2708
simplyfish
Posted on 04-11-2008 at 11:27:41 AM
sorry the background of the smilie is coloured and not transparent.
n°2709
sosoe222
Posted on 04-11-2008 at 11:46:07 AM
Do you have PSD files of those images?
n°2710
cradłe
Posted on 04-11-2008 at 11:59:29 AM
Lmao, don't you have a bigger one? i'll try to do something though :wink:
[C]radle.eXe
n°2711
cradłe
Posted on 04-11-2008 at 12:01:59 PM
'kay here you go:
[C]radle.eXe
n°2713
simplyfish
Posted on 04-11-2008 at 02:05:11 PM
LOL thanks, sorry I didnt explain myself, I didnt expect anyone to do it for me.  I just wondered what the best way was.  I dont have the psds?
If I did is there a quick technique.
n°2714
darklady
Posted on 04-11-2008 at 03:05:18 PM
Open it in an image program such as Photoshop or the Gimp and erase the background of the image. Then save it as a .gif file or a .png.  If it is animated, you would need an animation program to do it, because Photoshop or the Gimp do not save animations.
n°2715
Posted on 04-11-2008 at 03:11:24 PM
Topic moved.
n°2858
aqua crystal
Posted on 06-14-2008 at 04:02:17 PM
I thought that photoshop and gimp could save animations. Not really advanced things mostly simple like blinking smilies. Well I've used the gimp for animation anyway.
You can use something like DarkLady described. Though you have to be careful and you may need to redraw the outline. Before I had the gimp though I used to use Giffy.
