Windows Customization & Support : saab and 20 unknown users
Hai
n°2690
bajt
Posted on 03-26-2008 at 04:13:42 PM
Hai peeps, i am new here and i need some help if is possible i really wanna learn to use Photoshop and now im trying to make tux2, as tut says but i find problem i dont know to :
8. Create a new layer called "Left foot". Set these colors:
Foreground: R:224 j'ai:205 B:0 (or #E0CD00)
Background: R:223 j'ai:186 B:0 (or #DFBA00)
How to put that colors ? :frown:
Sorry for my english.
n°2691
Posted on 03-26-2008 at 04:40:55 PM
It's not hard to change the foreground color. You just have to double click the box which resembles the foreground color. It is on the bottom of the tool box. :oui: The same applies for the background color. :smile: You can post any questions about tutorials in the topic of the tutorial itself by the way. :wink:
n°2692
bajt
Posted on 03-26-2008 at 05:18:09 PM
Oke thanks mate, i will post there didin't know sorry again. Thanks for help mate its working :smile:
