21 unknown users
[Tutorial Request] How to Crystalize an Object.
n°2684
cradłe
Cradle-desktop@ubuntu:~$ whatis windows
Posted on 03-25-2008 at 02:36:45 PM
Hi, all members of CrystalXP.net ! :loveit:
My request is a tutorial on photoshop, on how to " Crystalize " any object.If someone could help me on this, i'd appreciate it  :jap:
Thanks in advance.
Sincerely,
[C]radle.eXe
n°2685
Posted on 03-25-2008 at 03:02:01 PM
The technique and procedure for the crystallization of different objects may not be the same but the basic elements are i.e: gloss , transparency and colors . The intelligent use of these may bring some crystal-look in the object :oui: .
n°2686
cradłe
Posted on 03-25-2008 at 03:30:21 PM
Hey Asher! And thanks a lot for your help.I appreciate it. I'll probably try that on my " new in-construction Signature. :wink: "
[C]radle.eXe
n°2687
Posted on 03-25-2008 at 03:31:56 PM
Good luck for that :wink:
:ar: Topic Moved
n°2688
Kirathehunter
Posted on 03-26-2008 at 01:48:38 PM
:biggrin: Thanks Asher for help, but it still not clear for me for every shape that I want to make...
I mean that some designs easily can be "Crystallized" but other designs need some knowledge of designing :oui: ...
n°2693
Posted on 03-26-2008 at 05:37:58 PM
Yes , the ways for crystallization are not same for all objects , so the explanation of crystallization can not be absolutely accumulated in single reply :he: ,  you can ask in this section for help regarding crystallization of any particular object though :wink:
