Any experienced photoshoppers know how to tint the color of an existing graphic?
Take the google logo for example:
How would I make all those letters green, or all of them blue, etc.?
Posted on 03-04-2008 at 02:55:52 PM
x3lumin8x
Posted on 03-04-2008 at 04:21:48 PM
Click: Image - Adjustments - Hue/Saturation or Ctrl+U. After opening, check the box that says Colorize. Experiment with sliders to get the effect you want.
Posted on 03-04-2008 at 05:13:44 PM
Topic moved. Please only post tutorials in this section. Questions and tutorial requests can be posted in the Graphic Novice Corner.
Repentless
Posted on 03-06-2008 at 02:35:10 PM
Thanks, I'll try it now and post my result when it's finished. This is for the doodle4google competition.
Genius is not born , it is made.... Profil: Moderator
Posted on 03-06-2008 at 05:42:00 PM
Hasn't the competition finished yet?I read about the winner here
