17 unknown users
How do I make this effect?
n°2628
haran
Posted on 01-16-2008 at 02:31:36 AM
I found this picture and it has a really cool glass type effect to it but I don't know how to do it but I do have photoshop.
Just wondering if someone can tell me how to achieve this effect...
http://i251.photobucket.com/albums/gg288/haran_hockey/cooleffect.jpg
n°2629
Posted on 01-16-2008 at 08:02:25 AM
As far as I can see, that's not very hard to create. :smile: Just create a new layer, make a white box and then lower the opacity to a level you think is sufficient.
Topic moved.
n°2630
haran
Posted on 01-17-2008 at 12:18:37 AM
Thanks. I actually figured out how to achieve this effect after I posted this. I just lower the opacity or fill to around 50%.
