Windows Customization & Support : saab and 19 unknown users
How do I tilt an image?
n°2586
Aipha
Posted on 12-11-2007 at 09:55:11 PM
Hi,
I'm creating a small animation and I can't find out how to tilt my image. If anyone here knows please reply. Your help is well appreciated. Sorry that I posted this in the wrong section.
:whistle:
n°2587
Cerberus1991
Posted on 12-11-2007 at 09:57:28 PM
Aipha wrote :
Hi,
:whistle:
Tilt image in photoshop:
Ctrl + T goto the outside of the box and youll see a curvy arrow. move downor up to tilt. then press the tick at the top
Hope that helps  :happy2:
n°2588
x3lumin8x
Posted on 12-11-2007 at 09:59:09 PM
If you're using PS, use the Transform options.
n°2589
Aipha
Posted on 12-11-2007 at 10:00:27 PM
Using Adobe Photoshop CS2. Thanks for the help :biggrin:
n°2590
Posted on 12-12-2007 at 03:56:08 AM
:ar: topic moved
