Hi guys!! I have just registered! can anyone tell me how i can hide/remove bin icon from the desktop (windows xp)? now i use rocket dock and so i'd like to remove that icon!
It's not very hard, but pay attention when you are doing it to avoid errors. Read here.
Edit: Welcome to CrystalXP!
Genius is not born , it is made.... Profil: Moderator
Posted on 10-21-2007 at 04:20:26 PM
I use Group Policy Object Editor for hiding and un-hiding Recyle Bin icon from desktop , to start it , go to Run and type "gpedit.msc" (without quotes) and press Enter , thereby enable this option:
I'm not sure how this will hide the Recycle Bin icon?
It gets rid of all icons on the desktop.
Well.... Hides.
suncity
Posted on 11-11-2007 at 08:20:16 AM
Start/run/regedit [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Desktop\NameSpace\ Delete {645FF040-5081-101B-9F08-00AA002F954E} Exit registry.Go to desktop and refresh.
Brightknight
www.designsbybk.com Profil: Penguin
Posted on 11-11-2007 at 09:19:37 AM
use TweakUI from microsoft. it does more than hiding the recycle bin.
