| Ryanfan Profil: New Penguin | how to make the frame that you allways use for your avatar? the thick frame | |
Gruzz Profil: Moderator | Please don't post questions in the Tutorial section. As an answer to your question, there is no quick way. You can have a look at this tutorial, it might help you out a bit. If you still don't understand, please ask. Topic moved. | |
Ryanfan Profil: New Penguin | Oh my god excuse. I do not understand very well what is written in the titles and descriptions. Excuse still
Don't worry, the moderators are here to help you.
Asher Genius is not born , it is made.... Profil: Moderator | Have a look at this tutorial of mine , may be it helps you  | |
Gruzz Profil: Moderator | My apologies, I totally forgot.
