15 unknown users
WAVE effect in the crystalxp header?
n°2517
Cife
Posted on 10-13-2007 at 03:42:30 AM
Does anyone know the name of the "wave" effect in the header at the top of the site? Or have a link to a tutorial that shows how to do it? I've been trying to duplicate the effect but can't get it to look good.
n°2518
Posted on 10-13-2007 at 09:01:15 AM
Welcome to Crystal XP Cife :smile:
The header of CrXP has some wide curves which can be obtained by using Pen Tool in Photoshop , you just need to make the background the curves will do the rest :wink:
A quick result by me:
http://img148.imageshack.us/img148/3696/curvesxb7.jpg
Topic Moved
n°2546
sunshift
Posted on 10-27-2007 at 06:52:59 PM
Could you explain a little bit further?  I'm still not sure how to get it.  I can make the swoopy lines with the pen tool, but how do I make them into gradients?  The gradient overlay only works with a mask right?  If its a shape, not a curvy line.
